Eachine produces a lot of quadcopters and some were not very successful. For example, the last Eachine Falcon 210 was clearly underpowered and too heavy.
Eachine proposes a new “pro” version still integrating an OSD and a 40CH 5.8G FPV: http://www.banggood.com/Eachine-Falcon-210-Pro-CC3D-Naze32-F3-FPV-Racer-RTF-with-OSD-700TVL-CAM-5_8G-40CH-VTX-i6-Transmitter-p-1112637.html. Now the main structure should be more lighter. 309g is announced versus 380g for the original EF210. 452g here in total versus 485g for the original version. I can still see 2204 motors where last Wizzard integrates 2205 motors a little bit more powerful.Anyway, the main guilty for the original Falcon were the ESC. Here we have some 20A (peak at 30A) supporting oneshot 125 but not multishoot. As many Eachine racers, 3 choices of flight controller is offered: CC3D/Naze 32/SPF3.
Description :
Remote Control Manual How to Enter the Menu How to safe the setting Connections
Brand Name : Eachine
Item Name : Falcon 210 Pro ARF
Item Specification Features
210Pro Frame Wheelbase : 210mm
Thickness : 3mm
Dimension: 195 x 170 x 60mm
Package : 420 x 270 x 95mm
Weigh: 309g (no battery prop)
Weight with Battery : 452g
Package Weigh: 1.4kg Compatible with 4-5 inch propeller
Compatible with 2204 motor
Can be used with 4S/3S battery
With Seft-protection function
With direction indicator LED
Inclined motor base design, fast speed
Removable protection motor base
ESC Model: Fairy-20A
Continuous Current: 20A
Instantaneous Current(10S): 30A
BEC: No
Li-Po Battery: 2-4S
Weight: 7G
Size(without plug): 28 x 15 x 6mm Motor Shaft Lock Protection(donÿt use the other programe, or the funtion will be damaged)
Support OneShot 125
Adopt powerful high performance MCU
Smaller size and lighter
Special for multirotor, more sensitive during flying
Strong adaptive ability
Support the refresh rate of throttle siginal up to 500Hz,compatible with multi flight controller(notice:>=500Hz is nonstandard throttle siginal)
Prevent locked rotor protection
No damping light
Motor KV:2300
MAX Thrust:440G
Length: 32.2MM
NO.OF Cell:2-4S
Diameter: 27.9MM
Framework: 12N14P
Shaft:3MM
Propeller:5-6 inch
Length of cable: about 3.5cm
Weight: 25G
Flight Controller CC3D / Naze32 6DOF /SP Racing F3 ACRO
Battery 3S 11.1V 1500mAh 25C Battery ,XT60 plug
700TVL Cam Power supply: 3.6-5.5V (powered off TX)
Power consumption: 60mA @5V
Imager: 1/3ÿ CMOS, more than 700TVL
Resolution: P:720*576 N:720*480
FOV: 127°diagonal 110°horizontal (ideal for fixed camera)
Lens: 2.6mm IR coated
FPV tuned light handling
NTSC or PAL (selectable; jumper on = PAL).
Operation Temperature: -20 to 70°C
Square: 24 x 17mm
Length includes the Lens and Socket: 32mm
Lens extrude (LxDia): 15mm X 14mm
Weight: 12g
FT200 VTX Modulate: Wideband FM Modulate
Video Format: NTSC/PAL
Output Impedance: 50 Ohm
Output Power: 23-24dBm
Channel: 40 CH
Operating Voltage: 7V-24V
Output Voltage: 3.6-5.5V
Supply Current: 190mA
Operating Temperature: -10~85 Video Band Width : 0~8.0 MHz
Audio Carrier Frequency: 6.5 MHz
Video Input Level: 0.8~1.2 Vp-p
Video Input Impedance: 75 Ohm
Audio Input Level: 0.5~2.0 Vp-p
Audio Input Impedance: 10K Ohm
Transmitting distance : ~1000m (open area)
LED indicators for Fr/Ch
Connector: RP-SMA Female
Antenna : RP-SMA Male,LHCP
Dimension: 38mm x 22.5mm x 6mm
Weight: 6g (without antenna)
Frequency and channel frequency table:
CH CH 1 CH 2 CH 3 CH 4 CH 5 CH 6 CH 7 CH 8
GROUP
A 5865 5845 5825 5805 5785 5765 5745 5725
B 5733 5752 5771 5790 5809 5828 5847 5866
E 5705 5685 5665 5645 5885 5905 5925 5945
F 5740 5760 5780 5800 5820 5840 5860 5880
R 5658 5695 5732 5769 5806 5843 5880 5917
i6
Transmitter Channels: 6 Channels
Model Type: Glider/Heli/Airplane
RF Range: 2.40-2.48GHz
Bandwidth: 500KHz
Band: 142
RF Power: Less Than 20dBm
2.4ghz System: AFHDS 2A and AFHDS
Code Type: GFSK
Sensitivity: 1024
Low Voltage Warning: less than 4.2V
DSC Port: PS2;Output:PPM
Charger Port: No
ANT length: 26mm*2(dual antenna)
Weight:392g
Power: 6V 1.5AA*4
Display mode: Transflective STN positive type,
128*64 dot matrix VA73*39mm,white backlight.
On-line update:yes
Color: Black
Certificate: CE0678,FCC
Model Memories: 20
Channel Order:
Aileron-CH1, Elevator-CH2, Throttle-CH3,
Rudder-CH4,
Ch 5 & 6 for reserve Works in the frequency range of 2.405 to 2.475GHz.
Uses a high gain and high quality multi directional antenna
Each transmitter has a unique ID
Low power electronic components and sensitive receiver chip.
AFHDS2A system has the automatic identification function
AFHDS2A has built-in multiple channel coding and error-correction
iA6
Receiver Channels: 6 Channels
Model Type: Fixed-wing/Glider/Airplane
Bandwidth: 500KHz
Band: 142
RF power:less than 20dBm
RF.receiver sensitivity:-105dBm
Code Type: GFSK
ANT length: 26mm
Weight:6.4g
Power:4.0-6.5V
Color: Black
Certificate: CE,FCC
i-BUS port: NO
Data Acquisition port:NO
1 x Falcon 210 PRO Frame Kit
1 x PDB
1 x OSD
4 x Motor Base
4 x 2204 Motor
4 x 20A ESC
1 x Flight Controller
8 x Propeller
1 x Power Connector
4 x LED
1 x 3S Battery
1 x B3 Charger
1 x 700TVL Camera
1 x Camera Mount
1 x 40CH 5.8G VTX
1 x Antenna
1 x Eachine i6 Transmitter
In the first glance, improvements are minor…. Anyway, if the pro version solves the underpower problem of the first edition… the pro version can be a nice suprize
Cet article NEWS: Eachine Falcon 210 Pro est apparu en premier sur Drone-Maniac !!!!!!!.
