A new AIO 25mw FPV camera enters into the dance, here announced to be a 3.8g 800TVL 1/3″ CMOS camera: http://www.banggood.com/Eachine-EF-02-AIO-5_8G-40CH-25MW-800TVL-VTX-13-Cmos-FPV-Camera-p-1119217.html
Works mainly with 1s system but not for 2s be aware. The main novelty versus the Eachine TX01 is the presence of a 800TVL 1/3″ sensor, so with a bigger sensor (1/3″ vs 1/4″)…. but no information about the light sensitivity. The field of view is still very large (170deg) so more adapted for indoors flyers… Probably a perfect compagnon for your Tiniwhoop FPV rig. Probably some fraction of gram can be saved by installing more a linear antenna. No possibiility to flip/Mirror the video.
Brand name Eachine
Item name EF-02 AIO FPV Camera
FPV Camera Sensor: 1/3 “CMOS
Lens: M7 800TVL Lens
Angle: 150 ° FOV horizontal viewing angle of 170 ° DFOV diagonal perspective
Format: NTSC / PAL (switchable)
Power consumption: 380mA @ 3.7V
Power: 3.6-5.5V
Lens Mirror Diameter: 2.1mm IR coated FOV150 (horizontal)
Transmitter Support video format: NTSC / PAL
Output Impedance: 75 Ohm
Output signal strength: 23 ~ 24dBm
Output Power: 25mW
Wireless Channel: 40CH
Operating voltage: 3.6V ~ 5.5V
Current: 100mA
Audio carrier: 6.5MHz
Button function
Short press (Apr. 1 sec or less): Change channels 1-8
Long press (More than 1.5 sec): Change bands A-B-E-F-R
Long + press (More than 3 sec): Change NTSC/PAL system
NTSC or PAL (selectable; Blue LED on= NTSC; Blue LED off=PAL)
Frequency Table
Frequency Band A 5865 5845 5825 5805 5785 5765 5745 5725
Frequency Band B 5733 5752 5771 5790 5809 5828 5847 5866
Frequency Band E 5705 5685 5665 5645 5885 5905 5925 5945
Frequency Band F 5740 5760 5780 5800 5820 5840 5860 5880
Frequency Band R 5658 5695 5732 5769 5806 5843 5880 5917
Body Weight: 3.8g
Size: 17x13x14.5mm (without antenna)
Feature:
AIO FPV camera, transmitter , antenna all 3 functions in one limit size and weight
Five bands 40 channels with Raceband
1 X EF-02 AIO FPV Camera
1 X Cable
Cet article NEWS: Eachine EF-02, 3.8g 800TVL 1/3″ CMOS 25mW AIO FPV camera est apparu en premier sur Drone-Maniac !!!!!!!.
