NEWS: Eachine Chaser88 (90g, 88mm 2S brushless, F3 mini, 25mW 40CH AIO FPV cam)
Based one the Eachine Falcon 120 (soon reviewed in drone-maniac), a new upgraded model is already announced by BG in ARF version: http://www.banggood.com/Eachine-Chaser88-F3-FPV-Racer-ARF-with-4-In-1-6A-ESC-5_8G-40CH-VTX-800TVL-13-Cmos-Camera-2-3S-p-1120343.html. A compact brushless quadcopter with 1103/10000 Kv motors, 6A BLheli_S ESC able to support up to 3S voltage and F3 mini betaflight compatible FC. The FPV ring includes a 25mW VTX, maybe a little bit weak for large range outdoors applications but since the total weight is announced to 90g, the machine can be also used indoors. In this case, we can regret the absence of prop guards … maybe the future Eachine aurora 90 will be more adapted for Indoors. We can guess in the design a rear LEDs bar probably configurable in BF. Props are super tiny, tri-blades 2″ model (2030) !!! This battery connexion seems to be done via a XT30 connectors. Flight time with a 2S 450mAh are announced to be around 3.5min… very disapointing :(. No builtin BetaOSD also …. I hope there is at least a builtin buzzer.
Specification Features:
Falcon 120 Frame
Package : 215×110×265mm
Weigh(without battery): 67g
Weight (with battery): 90g
Package Weigh: 215g
Compatible with 2030 inches propeller
Compatible with 1103 motor
Can be used with 2-3S battery
Wheelbase: 88mm
Flight time: 3.5mins
Batterry: 2S 30C 450mah
With direction indicator LED
ESC Model: BLHELI-S 6A
Continuous Current: 6A
Instantaneous Current(10S): 10A
BEC: NO
Li-Po Battery: 1-2S
Programming: Yes
Weight: 5G
Size(PCB): 27 x 27mm
M3 install Pitch: 20 x 20mm
Support DSHOT600
Motor 1103 10000KV
Voltage: 11.1V Power: 64.4W
Prop: 2 inches Efficiency: 1.4 g/w
Load current: 5.8A Lipo cell: 1-3s
Pull: 90g Weight: 3.7 g
Flight
Controller F3 Mini
Firmware version: bf 1.3.1
800TVL Camera Sensor: 1/3 “CMOS
Lens: M8 800TVL Lens
Angle: 150 ° FOV horizontal viewing angle of 170 ° DFOV diagonal perspective
Format: NTSC / PAL (switchable)
Resolution: NTSC: 960X480/ PAL:960X480
Power consumption: 380mA @ 3.7V
Power: 3.6-5.5V
Lens Mirror Diameter: 2.1mm IR coated FOV150 (horizontal)
FPV Transmitter Support video format: NTSC / PAL
Output Impedance: 75 Ohm
Output signal strength: 23 ~ 24dBm
Output Power: 25mW
Wireless Channel: 40CH
Antenna: RHCP circular polarization clover leaf antenna
Operating voltage: 3.6V ~ 5.5V
Current: 100mA
Audio carrier: 6.5MHz
Button function
Short press (Apr. 1 sec or less): Change channels 1-8
Long press (More than 1.5 sec): Change bands A-B-E-F-R
Long + press (More than 3 sec): Change NTSC/PAL system
NTSC or PAL (selectable; Blue LED on= NTSC; Blue LED off=PAL)
Frequency Table
Frequency Band A 5865 5845 5825 5805 5785 5765 5745 5725
Frequency Band B 5733 5752 5771 5790 5809 5828 5847 5866
Frequency Band E 5705 5685 5665 5645 5885 5905 5925 5945
Frequency Band F 5740 5760 5780 5800 5820 5840 5860 5880
Frequency Band R 5658 5695 5732 5769 5806 5843 5880 5917
1 X Frame Kit
4 X 1103 motor
4 X 2030 Propeller
1 X Camera
1 X VTX
1 X Antenna
1 X 4 IN 1 ESC
1 X Flight controller
1 X LED with Buzzer
1 X PLA Camera protection ring
Cet article NEWS: Eachine Chaser88 (90g, 88mm 2S brushless, F3 mini, 25mW 40CH AIO FPV cam) est apparu en premier sur Drone-Maniac !!!!!!!.
