Few months ago have started the war of FPV gogggles offering large FOV with at least 5″ builtin displays. The first model introduced was the headplay HD followed by a popular clone the Skyzone SJ-V01. At the time, Eachine introduced the Goggles ONE but a lot of fatal errors in the original design killed its potential success. A new revision is now introduced with Eachine Goggles 2 with the same screen caracteristic, an excellent 5″ supporting up to 1080P resolution but also in theory fixing all problems of the original EG1. More with the EG2, a diversity system is introduced to improve the general RX sensitivity.
+ 1 x Eachine Goggles Two
+ 2 x 2200mah 2S LiPo with DC connector
+ 1 x Power unit
+ 1 x 5.8G Cloverleaf antenna with RP-SMA connector
+ 1 x 5.8G Half-plannar antenna with RP-SMA connector
+ 2 x Facial sponge
+ 1 x HDMI cable
+ 1 x RCA to 2.5mm jack
+ 1 x Fresnel lens clearning kit
In term of dimension, the EG2 mimics perfectly the original size of the EG1, maybe the Goggles two is slighty taller. First visual difference, no more cheap plastic covering the body.. here we have a full EPO body and IMHO it’s a better choice. More … seems lighter too.
No more problem to fasten 5.8G antennas… A free circling gap have been introduced 🙂
Neither on top or the bottom sides, we can’t guess screws to split in two the goggles…
We retrieve the same 5 buttons of the EG1.
From left to right we have: “scan” button where in RF mode, a simple press run the scanning procedure over the 40CH, the “Source” selection between (RF/AV/HDMI). The current selected source is displayed during 5s on the top left of the screen. The third button is to enter into the menu or validate the current selection of a setting. The “+” in RFmode selects one the 40CH or decreases a value in the menu setting. The “-” in RFmode selects also one of the 40CH or increases a value in the menu setting. At the right of the buttons, we retrieve the HDMI input port in mini-format and a 2.5mm jack to plug either your earphones or an AV source. I deeply regret the absence of an AVout for an easy DVR pluggin to record your favorite FPV sessions …. A first mod to do IMHO
A large Goggles 2 sticker
The battery can be jailed into the headstrap 🙂
By default, no facial sponge is installed. You must tape of the two provided.
Not a lot of free room to wear the EG2 with large glasses ….
The battery have been upgraded to a 2S 2200mah (versus a 1600mAH for the EG1)
WIth this model, expect to enjoy at least one full hour of usage and as for the EG1, the current voltage is displayed on the lower left part of the screen. It will requires close to 2h to full recharge it. We can maybe regret the absence of a balancer plug for the battery.
Another improvement, not only the diversity is introduced but one antenna is a Cloverleaf model for proximity range
and the second a half-planner for long range FPV
Now RP-SMA connector are much more easy to access and to fasten the antenna
Good news, no more noisy fan…. the electronic have been upgraded and large aerial section is introduced to cool all conpounds
Weight
A total of 430g … with a larger battery … 🙂 A good news for your confort
Display
Generally, the good eyes, no problem of focusing and the image is crisp and precize. Personnally, I regret the non-possibility to tune the Fresnel lens distance. For my old eyes, I can’t perfectly read for example small bottom OSD informations.
– WIth a FPV source
On the bottom left, the current voltage of the battery, blinking when low-voltage is here. The right side shows the current frequency …. but not the current band. It’s a detail 🙂
Good news, you can force the aspect ratio in settings to 4:3, a nice introduction for the EG2.
– With a HDMI source
The screen is adapted perfectly. The image is precize and clear, ideal for Home cinema applications
Menu
UNBOXING & ANALYSIS
No more black-screen and the general RX sensibility is great !!!! Champagne 🙂
Six months have passed between the EG1 and the EG2 and all this time was really benefit for the new variant. I would say they fixed 99% of the original problem but not only: the diversity improves performances, the goggles is now lighter, a full OSD with a lot of paremeters are now available and we can now manually select some important parameters (Vfreq, video format, aspect ratio). Well this product is not yet perfect. Is missing at least an AVout to plug an external DVR and the possibility to tune the Fresnel lens distance for poor old eyes. A big bonnus would be to have a buitin DVR… probably in Goggles Three future release.
+ Super quality screen
+ 1080P resolution
+ Good RX senstivity
+ No black screen
+ Manual channel selection
+ Manual aspect ratio selection
+ Manual PAL/NTSC selection
+ Cloverleaf/Half-plannar antennas
+ Current channel displayed
+ A lot of settings available from the menu
+ HDMI input
+ HDMI cable
+ Confortable
+ Lighter than the Goggles 1
+ More than 1h of battery duration
– No Avout
– No builtin DVR
– No Fresnel lens distance ajustement
This FPV goggles have been courtesy provided by Banggood in order to make a fair and not biased review. I would like to thank them for this attitude.
You can find it actually for 140USD at http://www.banggood.com/Eachine-Goggles-Two-5-Inches-5_8G-40CH-Raceband-HD-1080p-HDMI-FPV-Goggles-Video-Glasses-p-1094862.html
Cet article TEST: Eachine FPV Goggles TWO est apparu en premier sur Drone-Maniac !!!!!!!.
