NEWS: FRFr3, FLFR3 and DSFR3 EVO 3g FC for brushed FPV machines
After the FrFR3 EVO I recently reviewed, here are 3 new versions of the brushed SPF3 FC including for all JST SH 1.0mm connectors for motors and FrSky, FlySly or DMS2/DSMX receivers. These boards only supports 1S cell LiPo. A buzzer and OSD can be directly added. All of them are announced to weight 3g.
For the FrSky D8 receiver version:
http://www.banggood.com/FRF3_EVO_BRUSHED-Flight-Controller-Built-in-Frsky-8CH-Sbus-Receiver-For-Eachine-QX95-QX90-QX90C-p-1105907.html
Brand Name: Eachine
Item Name: FRF3_EVO_BRUSHED Flight Controller Built-in Frsky Receiver
Item NO.: QX958FR
Dimension: 22mm*32.5mm
Thickness: 1.2mm
Weight: 3g
Receiver: Frsky 8CH sbus receiver(D8 mode)
Coreless motor plug: SH1.0
Firmware: SP RACING F3 EVO 1.13.0
Support work voltage: 3.6v~4.2v(1S Lipo battery
1.F3_EVO_Brush revision is out of the F3 EVO SP RACING is based on a SP RACING F3 EVO firmware 32 brush flight control.
2.Independent design of the circuit structure
3.Using STM32F303CCT6 + MPU6500, advanced hardware platform F3 guarantee more stable flight.
4.With a large and high quality current NMOS transistors, operating current of up to 10A or more. Each Brushed motor is equipped with freewheeling diodes.
5.Integrated 2.4G Frsky 8CH sbus receiver(D8 mode).
6.With battery voltage detection and buzzer interface(solder pad)
7.LED_STRIP Function(solder pad)
For the FlySky AFHDS receiver version:
http://www.banggood.com/FLF3_EVO_BRUSHED-Flight-Controller-Built-in-Flysky-6CH-PPM-Receiver-For-Eachine-QX95-QX90-QX90C-p-1106427.html
Brand Name: Eachine
Item Name: FLF3_EVO_BRUSHED Flight Controller Built-in Flysky Receiver
Item NO.: QX958FL
Thickness: 1.2mm
Weight: 3g
Receiver: Flysky 6CH PPM Receiver (AFHDS)
Support work voltage: 3.6v~4.2v(1S Lipo battery)
5.Integrated 2.4G Flysky 6CH PPM receiver (AFHDS).
and for the DSM2 spektrum version:
http://www.banggood.com/DSF3_EVO_BRUSHED-Flight-Controller-Built-in-DSM2-6CH-PPM-Receiver-For-Eachine-QX95-QX90-QX90C-p-1106426.html
Brand Name: Eachine
Item Name: DSF3_EVO_BRUSHED Flight Controller Built-in DSM2 Receiver
Item NO.: QX958DS
Thickness: 1.2mm
Weight: 3g
Receiver: DSM2 6CH PPM Receiver
5.Integrated 2.4G DSM2 6CH PPM Receiver.
They share for all the same wiring diagram. Ideal for mini FPV racer … ?
Cet article NEWS: FRFr3, FLFR3 and DSFR3 EVO 3g FC for brushed FPV machines est apparu en premier sur Drone-Maniac !!!!!!!.
