NEWS: Headplay SE V2 FPV goggles (7″ HD 15ms low latency screen, builtin DVR, improved RX)
A new revision of probably the most popular large screen FPV goggles in the market: http://www.banggood.com/Headplay-SE-V2-5_8G-40CH-FPV-Goggles-Video-Glasses-Headset-With-DVR-p-1126187.htmlNow with the SE V2 edition we have a low latency 7″ LCD screen (announced to be < 15ms) without black/blue screen when the FPV signal is lost. They include a new Fresnel lens with a narrower FPV but more accurate and precize, more adapted for FPV racing.HDMI input is still here but the general confort have been improved. Main introduction of a builtin DVR !!! that's great to record your favorite FPV session. The 5.8G part have been also improved with a 40CH receiver with higher sensitivity, an autoscan function.... but no diversity yet. The goggles can be powered directly from a 2S up to a 4S LiPo battery and they changed their main lead connectors as well. Wait & See. null
Brand Name :  Headplay
Item Name:  Headplay SE V2
Frequency :5.8G
Channel : 40CH
Voltage Input : 2s-4s LiPo XT60(not included)
Latency : 15ms
Low latency LCD -best racing performance
15 ms low latency video- even during active DVR recording
Never blue or black screen during FPV
HDMI-in for HD FPV
Smart design prevents cable from snapping if pulled by accident
Plug-and-play with HD FPV links
Patented ergonomic design
Light weight
Classic Headplay design spreads weight evenly on forehead and cheeks
Superior comfort, materials, fit and finish
Three point adjustable straps with silicone ant-slip belt
Five new colors : Monster Green, Platinum Silver, Battleship Gray, Headplay Blue, Matte Black
Rubber texture resists scratches and keeps new appearance longer
Headplay F220 mm lens
For a cinematic immersive feeling
HPRO lens
HPRO lens is included and offers a much more  narrow FOV for fast FPV racing action
AV-in for connecting to FPV base station
Connect the Headplay to your existing FPV receiver
AV-in and AV-out are connected to the DVR, but it’s possible to disconnect the DVR and DIY connect AV-in (i.e. 1.3 GHz video Rx) to the AV-input ; and if you keep the AV-out connected to the DVR, you can record the external AV input with the DVR
XT60 battery input for all day run time
Simple and smart battery holder for standard 2S-4S racing packs with XT60 connector
OSD voltage display with low battery warning
Voltage display can be moved to any corner of the screen or turned off
New 5.8 GHz receiver with autoscan channel finder
Design by Hawkeye
Improved sensitivity over previous Headplay Rx
40 channels with Raceband channels
Band and channel indicator LED
Band and Channel selection
1 x Headplay SE
1 x XT60 power harness/DVR harness
1 x Face foam 7 mm
1 x Face foam 15 mm
Cet article NEWS: Headplay SE V2 FPV goggles (7″ HD 15ms low latency screen, builtin DVR, improved RX) est apparu en premier sur Drone-Maniac !!!!!!!.
