NEWS: Eachine QX110 “Vtail” (~60g, AIOF3pro, 0820/dark edition, 600TVL-1/4″ CMOS AIO camera)
After the Eachine “Bat” QX105, IMHO, a model not to recommand due to weak FET not compatible with 1020 motors, here is the Eachine “Vtail” QX110: http://www.banggood.com/Eachine-Vtail-QX110-w-AIOF3PRO_Brushed-OSD-Betaflight-600TVL-CAM-Micro-FPV-Racing-Quadcopter-BNF-p-1126256.html. Here, bye bye 1020 motors and welcome back 0820 motors but on steroids (black edition) !!. More with the QX110 we have a Vtail architecture expecting to offer much more yaw authority during fast u-turns. I really hope the Vtail system is not simply installed via plastic pads like for the big brother Eachine Vtail 210. More arms seems to be 1mm of thickness only and the landing gear a bit fragile too. Anyway, all other ingredients sound really good. A F3 board including a builtin betaflight OSD, strong motors, builtin buzzer, programmable rear LED lights, basic 600TVL 1/4″ CMOS AIO camera and as usual three choice of receivers: FrSky D8 (RSSI & Vbat telemetry working),FlySky (AFHDS ?) and Spektrum DSM2/DSMX. Announced to be 47g w/o battery so add 12g with… the machine should turn below 60g so clearly 26g less than QX105.
The Eachine Vtail QX110 is a New Design Micro FPV Racing Drones built-in OSD for Indoor FPV. The Vtail design that can make the FPV flight and traversing more flexible. The QX110 comes with Betaflight firmware which can bring you an amazing FPV flight experience. The Black Edition 8520 Coreless motor provide more powerful output which makes the QX110 more stable and faster. The adjustable angle of camera, The OSD , The LED_Strip, The carbon fiberglass frame, The buzzer , All that you can thought of the equipment for the FPV flight, it has all ready.
Brand Name: Eachine
Item NO.: Vtail QX110
Wheelbase: 110mm
Weight: 46g (Without Battery)
Flight controller: Eachine AIOF3PRO_Brushed built-in OSD
Firmware of Flight controller: Betaflight 3.0.1 (Target:Omnibus)
Motor: Coreless 8520 Black Edition CW/CCW
Propeller: Ladybird 55mm CW/CCW 2-blades propeller
Camera: 600TVL HD CMOS 1/4inch
VTX: 5.8g 25MW 48CH NTSC/PAL Video transmitter
OSD: Betaflight OSD
Battery: 3.7V 600mah Lipo battery
Flight time: 5 minutes (Battery voltage at 2.8v)
More powerful Coreless motor
Jaw-dropping flight performance
Airmode/Angle/Acro mode support
Adjustable Angle of Camera (0°~15°)
Built-in Betaflight OSD
Radio Stick to control PID Tunes
LED_STRIP Ready
Buzzer Ready
Telemetry RSSI Output ready
V-bat Detector
Receiver Option:
-Frsky D8 mode SBUS Output 8ch With RSSI output (OSD display or X9D telemetry)
-Flysky compatible 8ch PPM receiver(AFHDS 2A Mode)
-DSM2/DSMX compatible Receiver
Compatible:
1. Frsky Receiver compatible with FRSKY X9D/X9D PLUS(D8 mode),and XJT (D8 Mode),DJT DFT DHT.
2. Flysky Receiver compatible with FS-i4, FS-i6, FS-i6S, FS-i6X, FS-i10, FS-GT2E, FS-GT2G, FS-GT2F.
3. DSM2/DSMX compatible Satellite receiver
1 x QX110 Frame kit
6 x 8520 Black Edition Coreless Motor
1 x AIOF3PRO_BRUSHED Flight Controller Built-in RX
1 x 5.8G VTX w/Camera antenna
8 x 55mm Propeller
2 x 3.7V 600mah Battery
1 x LED_STRIP
1 x Buzzer
1 x USB Charging cable
1 x Paddle propeller
Cet article NEWS: Eachine QX110 “Vtail” (~60g, AIOF3pro, 0820/dark edition, 600TVL-1/4″ CMOS AIO camera) est apparu en premier sur Drone-Maniac !!!!!!!.
