NEWS: CUAV VMR32 (32CH 5.8G VRX to OTG for androids/PC and iOS ?)
A new 5.8G VRX with OTG connexion is available here: http://www.banggood.com/CUAV-VMR32-5_8G-32CH-OTG-FPV-Receiver-Mobile-Phone-Gound-Station-For-Android-Smartphone-iPad-PC-p-1127474.html. A 32CH (no raceband supported) 5.8G VRX outputing the video in VGA (640×480) format. Announced to work for android/PC and Ipad even if in the chinese I didn’t see anything talking about the iOS comptability. (only an android APK is available currently). Can be very usefull to transform a smartphone/tablet into a new FPV ground station for the assistance.
Resolution : 640*480 30fps
Working Temp.: -10?-+60?
Working Voltage : USB5V/9v-32v
Working Current : USB 5V 250mA
Color : Gold,Gray,Black
Size : 43mm x 56mm x 11mm(withou antenna)/80mm(antenna height)
Weight : 56g
Connector : RP-SMA
5.8G 32CH Frequency
Auto Search Frequency
Equip with LED Displayer
Compatible with CUAV 5.8G Transmitter and other 5.8G Transmitter
Support Anderson iPad, PC ,smartphone which have OTG and AV monitor
Adopt CNC shell, sturdy construction, anti-inteference, bettery for cooling.
Built in 32 bit MCU
Auto save channel when it power off.
Operation:
Smarphone:
1. Android smartphone install the video software
2. Connect VMR32 via OTG cable(no need extra power supply)
3. When the VTX working normal, press the receiver button to search the frequency and see the live image.
PC:
1. Connect PC with USB
2. Open AMCAP camera software or MP goundstation
AV Monitor :
1. Solder the cable, customise the AV connector on monitor, power supply for receiver 3-6S
2. When the VTX working normal, press the receiver button to search the frequency and see the live image.
Package Included :
1 x CMR32 Receiver
1 x Clover Antenna
1 x USB Data Cable
1 x OTG Cable
Cet article NEWS: CUAV VMR32 (32CH 5.8G VRX to OTG for androids/PC and iOS ?) est apparu en premier sur Drone-Maniac !!!!!!!.
