A new compact HD 1080p camera broadcasting the FPV signal in VGA format is announced here: http://www.banggood.com/WST-1080P-HD-Mini-DV-CAM-Mini-FPV-Camera-Support-SD-for-FPV-Racer-p-1128903.html. We have only 1080p@30fps or 720p@60fps… No information about the FOV of the associated lens, neither for the light sensivity value of the sensor and the latency associated with. Close to be twice cheaper than a mobius mini but is only 2g less…. At least you can select your lens orentation and recording can be triggered via PWM connexion. Should work from 1S setup and a Vreg is required from 2S and more setup.
Operating Voltage: 3.7-5V
Current Consumption: 280mA
Recording Resolution: 1080P(30FPS)/720P(60FPS)
Recording Format: MOV
Support TF Card: max 32GB
Video Output: VGA640*480 NTSC/PAL/1Vp-p
Dimensions: 71*40*16mm
Weight: 25g
1 x 1080P HD Camera
Cet article NEWS: WST 1080p mini (1080p@30fps + VGA FPV) est apparu en premier sur Drone-Maniac !!!!!!!.
