NEWS: XJB-80 (80mm, 73g, 3S, 1104/7500, F3 Evo, 200mW AIO)
Want a tiny 80mm brushless 3S conpatible ? a kind of Eachine Chaser 88 with builtin propguards and Under steroids?. Here is the XJB-80: http://www.banggood.com/XJB-80-80mm-5_8G-40CH-Mini-FPV-Racing-Drone-wF3-OSD-25A-Blheli-ESC-600TVL-14-Cmos-p-1129495.html. Strong 4-in-1 25A BLheli_S ESC (4S supported !!!!!), 1104/7500KV 3S motors, F3 evo board, builtin buzzer and a switchable power AIO FPV camera !!!. Camera can be tilted up to 30 degrees. Sounds just great … just miss the builtin betaflightOSD :). 73g standalone so with a 3S 300-400mah battery should turn around 100g. They propsed to fly with a 550mah model (should scale around 110g IMHO). Come in ARF of BNF version: FrSky D8 (w/ telemetry) or FlySky (probably AFHDS-2A).
Specificaton:
Item name: XJB-80 Mini FPV Racing Drone BNF
Wheelbase: 80mm
Weight: 72g( battery not include)
Motor: FLAME 1104 7500KV brushless motor(2S pull 120g,3S pull 200g)
ESC: XR396-25A BLHELI 2-4S 4 in 1 ESC
Propeller: 50mm 5 blade Propeller
Camera: 600TVL HD CMOS 1/4 inch
VTX: 5.8g 0/25/50/200MW 40CH NTSC/PAL video transmitter
Flight controller: HGLRC PBF3-EVO Betaflight F3
Firmware of flight controller: Betaflight 3.01
Flight time : 5minutes
Rear LED Ready (LED_Strip function)
Buzzer Ready
Battery: HGLRC 11.1V 550mah 35C lipo battery
HGLRC PBF3-EVO Betaflight F3:
Mount hole: 20mm*20mm
2OZ*4 Layer Board
Processor: STM32 F303 MCU
Sensor: SPI Sensor MPU6000
Firmware version: Betaflight 3.01
Target: PIKOBLXF3
Receive:SBUS/DSMX/PPM ETC
Telemetry Support
Transponder Support
HGLRC XR396 25A BLHELI 4 in 1 ESC:
2OZ*6 Layer Board
F396 Chip
Lipo Battery: 2-4S
Con. Current: 25A
Peak Current: 35A (20S)
Programming: YES
Betaflight passtrough ready
Support oneshot42 oneshot125 Multishot
Damped light on
-Extremely light and more powerful
-STM32 F303MCU(MPU-6000SPI) + 4in1BLHELI ESC make your Operating feel
more stabilly and silky
-30′ Angle of camera
-Jaw-dropping flight performance
-Cleanflight/Betaflight support
-Acro mode / Air mode /Angle mode support
-Radio Stick to control PID Tunes
-BLHELI pass-through ready
-Telemetry RSSI Output ready
-Weight Only 110g(include battery)
-XR396 4IN1 ESC Supermin Size 27*27,Max Current 140A, Conjunction with
PBF3 EVO Use 160-250MM drone
-High precision 3D protect frame
Notice:
1. BNF receiver option:
Compatible Frsky SBUS receiver
Compatible Flysky 8CH AFHDS2A receiver
2. Compatible:
1). Frsky Receiver compatible with FRSKY ACCST, X9D(Plus)DJT/DFT/DHT
2). Flysky Receiver compatible with FS-i4, FS-i6, FS-i6S, FS-i6X, FS-i10, FS-GT2E,
FS-GT2G, FS-GT2F
1 x XJB-80 Frame kit
1 x PBF3-EVO Betaflight F3
1 x Frsky/Flysky AFHDS2A (optional) (ARF version not include)
4 x FLAME 1104 7500KV brushless motor
1 x XR396 25A BLHELI 4 in 1 ESC
4 x 50mm 5 blade Propeller
1 x 600TVL HD CMOS 1/4 inch camera
1 x 5.8g 0/25/50/200MW 40CH NTSC/PAL video transmitter
1 x 1.1V 550mah 35C lipo battery
Cet article NEWS: XJB-80 (80mm, 73g, 3S, 1104/7500, F3 Evo, 200mW AIO) est apparu en premier sur Drone-Maniac !!!!!!!.
