There are many Syma X8 clones around the corner. The Xin Lin X8G is a new one: http://www.banggood.com/XIN-LIN-XINLIN-X8G-5_8G-FPV-With-2_0MP-HD-Camera-GPS-Altitude-Mode-RC-Quadcopter-RTF-p-1131858.html.
The originality of this new one is to add to the same brushed design some GPS features (altitulde hold and RTH) and a complete 5.8G rig. The machine comes in RTF format even including a small 4.3″ FPV monitor. The FPV camera is also able to record videos probably in 720p resolution. Well .. strange to see a GPS module on a large brushed model but for this solution represents probably the cheapest in the market. I regret the abssence of a wider lens to enjoy much better the FPV immersion. The control range is announced to be around 320m… not so bad and expected flight time about 10min… Unfortunatly, the pitch orientation can’t be ajusted by the radio.
Unfortunatly, still a narrow pinhole lens …. 🙁🙁 How it’s possible to imagine to fly without stress in FPV with such lens ?
Brand name: XIN LIN
Item No.: X8G
Color: Black, White
Charging time: 150 mins
Flying time: About 10mins
controll distance: 320m
Working frequency: 2.4Ghz
FPV frequency: 5.8G
Size (LxWxH): 60X60X20cm
Flight battery: 7.4V 2000mAh Li-Po battery
Transmitter battery: 4 x AA battery( not included )
Night Flight: Yes
Functions: Camera, GPS, One press home, High hode mode, Headless mode, Hover, Up/down, 3D rollover, Forward/backward, One Key Automatic Return, Turn left/right, Speed up, Sideward flight
Feature:
With 5.8G FPV 2.0MP HD Camera. Real-time video transmission capabilities, remote control LCD screen can playback video.
With GPS auto positioning system, accurate positioning location.
Large 7.4V 2000mAh capacity battery ensures the strong power, Superior 10mins long flight time.
With headless mode function,no need to adjust the position of aircraft before flying ..
With one key return function, makes it easily to find the way home.
With high density air pressure sensor which can precisely hold the height.
With 6-axis gyro which can have more stable flying and be easy to control.
With highlight LED lights, make it more dazzle beautiful and colorful night light.
1 x XIN LIN X8G RC Quadcopter
1 x Transmitter
1 x Monitor
1 x 4G Memory Card
1 x Battery Charger
4 x propeller
1 x 7.4V 2000mAh Li-Po Battery
1 x English manual
Cet article NEWS: Xin Lin X8G, brushed 350mm Syma X8G clone with GPS & 5.8G FPV est apparu en premier sur Drone-Maniac !!!!!!!.
