NEWS: ARFUN 90mm (F3+betaflightOSD, 4-in-1 20A BLheli_S/Dshot600, DYS 1104/7500Kv,3K 3mm frame, 600TVL 48CH 5.8G AIO)
A new promising microbrushless FPV racer is announced here: http://www.gearbest.com/brushless-fpv-racer/pp_617108.html
3mm of thickness !!!!! F3 board with Betaflight OSD, strong 20A 4in-1 BLHeli_S Dshot600 ESC board, DYS 1104/7500KV (should be 3S compatible), 600TVL CMOS 48CH 5.8G AIO cam, builtin buzzer and strong light πŸ™‚ what else ? A serious competitor to the new Aurora 100 !!!. I asked to review this one but according to my source, this product won’t be available before April.
Main Features:
– True β€œX” carbon fiber frame, perfectly symmetrical, with 3mm thickness and smooth edges
– Mini F3 flight control system with OSD supports PPM / SBUS / DSM2 / DSMX receivers
– Superior operation with 4-in-1 BLHeli – S 20A ESC which uses the latest DShot signals
– Outstanding 600TVL HD CMOS camera, extremely sensitive to light, offers you high-quality image
– 5.8G real-time image transmission, 48CH wide coverage within 200m range
– Powerful DYS BE1104 brushless motor. Each can generate up to 118g thrust
– The alarm can give out 80dB loud noise and 10 lm strong light to keep track of your UAV
– Well-balanced and suitable for flying indoors and outdoors thanks to the five-blade propellers
Flight control system: Tower Mini F3
3K carbon fiber frame thickness: 3mm
Brushless motor: DYS BE1104 7500KV
Brushless ESC: 4-in-1 BLHeli – S 20A
Propeller: 1935 five-blade, 50mm long
Video transmitter: 5.8G 48CH 25mW
Camera: 600TVL HD CMOS
Field of view: 120 degree
Image transmission range: 200m
Antenna gain: 3dBi
Alarm: audible ( 80dB ); visible ( 10 lm )
Power supply: 7.4V 300mAh 25C LiPo ( included )
Note:
There are different colors of the propellers, which is subject to stock availability.
Although the ESC supports 2 – 4S LiPo, the flight controller only supports 2 – 3S LiPo.
Cet article NEWS: ARFUN 90mm (F3+betaflightOSD, 4-in-1 20A BLheli_S/Dshot600, DYS 1104/7500Kv,3K 3mm frame, 600TVL 48CH 5.8G AIO) est apparu en premier sur Drone-Maniac !!!!!!!.
  • 4 weeks later...
