NEWS: Eachine VR-D2 Pro (Diversity, -95dBm, DVR, RSSI landscape, opensource)
Here is the new upgraded version of the popular goggles Eachine VR-D2. Now the pro version is introduced: http://www.banggood.com/Eachine-VR-D2-Pro-Upgraded-5-Inches-800480-40CH-5_8G-Diversity-FPV-Goggles-with-DVR-Lens-Adjustable-p-1137808.html
The new version represents a fantastic upgrade. If the the screen is still a 5″ 800×480/500cd/m2, they upgraded receivers for -95dBm model !!! and diversity is also here. More the goggles’s OS is open source and can be flashed/updated too A lot of option can be set and a full 5.8G scanning landscape is now also displayed. The Fresnel lens distance can be ajusted too …. Cherry on the cake, a buitkin DVR is added to record your favorite FPV flight. Can be a great first FPV goggles. The price is attractive and two hi-gain linear and circular antennas are provided. …. We can only regret the non-introduction of a 800×600 screen … Be sure the deluxe Eachine Goggles 2 will be also upgraded to a pro (or a 3) version relatively soon.
Brand name: Eachine
Item name: VR D2 Pro FPV Goggles
Screen size: 5 inches
Screen resolution: 800×480
Frequency channel: built-in 40CH 5.8GHz receiver
Battery : 2S 7.4-8.4V Lipo battery
Battery work time: 2.5-3 hours
Operating current: 600–680mA
Receiver sensitivity: -95dBM
Antenna connector: RP-SMA
DVR Max Support: 64G TF Card
Goggles weight: 285g (without antenna)
Antenna weight: 29 g (Flat: 13g, mushroom: 16g)
Dimension(mm): 150 X152 X96 (without antenna and antenne mount)
Feature:
New Logo, New Design
Upgraded Open Source Receiver, increases the sensitivity of receiver
Auto search, you can search all frequencies around or select your own frequency to avoid interference
Add the power indicator function instead of the built-in buzzer, you can check the power on displayer directly.
With white noise and snow screen
Dual receiver to get strong and steady signal
Support Lens Adjustable
Support upgrading
Built-in DVR function, record every wonderful moment and play back
With comfortable face sponge
With accurate capacity, 7.4V 2200mAh Lipo battery consists of 2 x 18650 battery
Support one key into power saving mode
1 X VR D2 Pro FPV Goggles
1 X Mushroom antenna
1 X Flat antenna
1 X 7.4V 2200mAh Lipo battery
1 X Charger
1 X User Manual
Cet article NEWS: Eachine VR-D2 Pro (Diversity, -95dBm, DVR, RSSI landscape, opensource) est apparu en premier sur Drone-Maniac !!!!!!!.
