NEWS: HMDVR-HD mini: a lightweight 1080p@60fps camera with low latency FPV (22g)
Remember the excellent performances of the FPV camera of the Eachine V-tail 210 ?. Here is the standalone module, the HMDVR-HD mini module: http://www.banggood.com/HMDVR-HD-1080P-HD-DVR-Mini-Camera-AV-Output-Low-Latency-for-FPV-Racing-Drone-p-1140482.html, including a pretty good 1080p@60 camera and broadcasting the FPV signal with low latency (~60ms) in NTSC or PAL format. This module comes with a plastic casing for a total weight of 22g. Few grams can be saved easily without the casing. Good news, there is also an AVin to connect it with an OSD. In fact this module can be found seperatly with the 1080p camera stanalone here: http://www.banggood.com/Eachine-V-tail-210-FPV-Drone-Spare-Part-1080P-Camera-13-inch-HD-CMOS-Switchable-NTSC-PAL-p-1100010.html and the DVR here: http://www.banggood.com/Eachine-V-tail-210-FPV-Drone-Spare-Part-HMDVR-HD-1080P-DVR-Switchable-NTSC-PAL-p-1100009.html
Here is a raw video sample
Brand: Happymodel
Item name: HMDVR-HD
Video format : NTSC or PAL Switchable
Records effective pixel : 1920(H)x1080(V)
Records frame rate : 60Frames
Compress format : MOV
Video output size : 640×480
Size : 50mm x 22mm
Weight : 6g
Max support 32G TF Card
Auto-save function : Auto-save every 5 minutes
Usage: for Happymodel V-tail 210 FPV Drone
1 x HMDVR-HD 1080P HD DVR Mini Camera
Cet article NEWS: HMDVR-HD mini: a lightweight 1080p@60fps camera with low latency FPV (22g) est apparu en premier sur Drone-Maniac !!!!!!!.
