Another ultralight weight D8 FrSky receiver (1.1g with the antenna) supporting PWM, PPM and SBUS connexion !!!. Here is the 8CH D8 mini FrSky: http://www.banggood.com/2_4G-8CH-D8-Mini-FrSky-Compatibel-Receiver-With-PWM-PPM-SBUS-Output-p-1140478.html. The associated range is announced to be superior to 300m… Not bad at all. No information about a working failsafe and the telemetry, but since there is no pads for the Vbat… probably, if there is a working telemetry, only the RSSI will be send. In practice it’s hard to find a 100% working micro FrSky receiver with good range and a full working failsafe and telemetry. The module can be used for 1-2s system directly.
Item Name: Mini Compatible Receiver
Number of channels: 8CH
Output signal: 8-channel PWM output, PPM output, SBUS output
Supply voltage: 3.3-10V
Supply current: 25MA @ 5V
Distance: > 300 meters
Maximum size: 18 * 14MM
Weight: 1.1 g (with antenna)
Compatibility: FrSky transmitter/transmitter modules in D8 mode
1X 8CH D8 PWM Mini Compatible Receiver
Cet article NEWS: 8CH D8 mini FrSky compatible receiver (1.1g) est apparu en premier sur Drone-Maniac !!!!!!!.
