It’s not an AIO FPV camera but a switchable power 5.8G VTX including a builtin DVR and up to 72CH: http://www.banggood.com/Eachine-DTX03-DVR-5_8G-72CH-025mW50mW200mW-Switchable-VTX-w-Audio-NTSCPAL-p-1141123.html. You select either 25mW, 50mW or 200mW. Works fine from 1s up to +5V but you will need a BEC/Vreg from 2S systems. Definitively, I hope the DVR part will be superior to their former 4-in-1 module where when recording was turned on, the FPV connexion became so laggy…. Impossible to fly FPV in such conditions. It seems to be since I can recognize the three button of a HMDVR module. 7g standalone… so you will have to add two extra gram for the FPV cam. Clearly more adapted from 120mm brushless machine.
Brand name: Eachine
Item name: DTX03 DVR FPV VTX
Output power: 0/25mW/50mW/200mW switchable
                       (Set output power on 0, to avoid frequency interference)
Input voltage: 3.2-5.5V
Current consumption: 630mA-390mA(25mW)
                     750mA-450mA(50mW)
                     970mA-550mA(200mW)
Video system: NTSC/PAL
Video format: AVI
Output signal strength: 14 ± 1db
Output impedance: 55O
Audio carrier: 10KO
Audio carrier level: -28- -30dBc
Micro SD Card: Max 32GB (CLASS 10)
Operating temperature: -10 – 60 degrees C
Antenna dimensions: 22mm X 29mm diameter
Antenna: 4 lobe right hand circular polarized
Frequency: 5.8GHz 9 bands 72 channels, with Raceband: 5325-5945 MHZ
Weight: 6.97g
Operation:
1. The menu Settings
– Short videos, click the CS2 key end video, long press the CS2 again can enter the Settings menu function
Long press CS2 again can exit menu function set to return to the main page
– Quit video, enter the menu function keys need short press + long press CS2, CS1 and CS3 choose for scroll
up and down keys.Long click CS2 can exit menu to return to the main page
2. Video recording
– Insert SD card boot default automatic video, short press the CS2 key end video, short press the CS2 key again for the next round of video
3. Video playback
Long press CS1 enter the video play page, CS1 and CS3 choose for up and down keys,
CS2 button to play and pause,then long press CS1 can exit play video reverse back to the main page
4. Adjust the power operation
– Powering on the vtx, blue LED display 0, indicating the vtx is powered on, but it is in off status without
any transmission
– Short-press the button to change channel (CH), digital display will change synchronously. Digital display
changes cyclically from 1 to 8
– Long-press the button for 2 seconds until digital display flicker. Then short-press the button to
change the frequency band (FR), digital display will change synchronously. Digital display changes
cyclically from A b E F r U o L H
– Long-press the button for 5 second until digital display flicker.
Then short-press the button to change the power, 25mW/50mW/200mW (one hyphen stands for 25mW,
two hyphens stand for 50mW,
and three hyphens stand for 200mW)
– 5 seconds after setting, CH, FR and power will flicker alternately
NOTICE: The vtx has memory for settings. To change the settings, please repeat steps as above
0 / 25mw / 50mw / 200mw switchable
With digital display,all by your control
Ultra-frequency,72CH give you unlimited space
With DVR function, images can be acquired and recorded in real time
Unique storage memory function, super audio processing technology,a key to playback
1 x Eachine DTX03 FPV transmitter
Cet article NEWS: Eachine DTX3, switchable power 5.8G VTx with builtin DVR est apparu en premier sur Drone-Maniac !!!!!!!.
