NEWS: Eachine Racer 250 pro ( Blheli_S/Dshot 20A, F3+OSD, 1000TVL CCD , 600mW 32CH)
Remember the first Eachine brushless racer ? their popular Racer 250, a 2 years old machine if I am not wrong. Here is the pro version: http://www.banggood.com/Eachine-Racer-250-PRO-FPV-Drone-Blheli_S-20A-F3-1000TVL-CCD-Camera-VTX-OSD-w-I6-Remote-Control-RTF-p-1142642.html. To make simple, everything have been upgraded except the nylon frame … Now we have strong 20A BLheli_S/Dshot ready ESC, 4S battery, a 1000TVL CCD FPV camera, a F3 board including a builtin OSD, some lights (not programmable), 600mW 32CH VTX (no raceband 🙁 ) As many RTF model of Eachine, the radio part is FlySly AFHDS-2A based with a classic FlySky i6 radio. The FPV camera can uptilted up to 25deg. I guess it’s the same model as for the Eachine Racer 180, an excellent one. I add now the more positive argument is the price !!! 220 USD for a RTF model … equiped of last technologies… can be the ideal first brushless racer. Well my unique concern is about the frame… 100% nylon based obviously less strong than a carbon one.
The machine is also lighter… 313g w/o battery, should turn less than 500g with the 4S battery.
Eachine Racer 250 PRO
Main wing: 63.5mm
Weight: 313.3g(without battery)
Fly time: 8-10 mins
Working temperature:  -10°C to +40°C
Package size: 310*310*150
Package weigh: 1550g
 Compatible with max 5 inch propeller.
With direction indicator LED.
Standard F3 6DOF flight controller, more stable flight.
Powerful 2205 2300KV brushless motor.
Blheli_S 20A ESC, supports Dshot300 Dshot 600
1100mah 4S 14.8V 30C lipo battery, get longer flight time.
5.8G 600mw 32ch real-time video transmission built-in OSD.
1000TVL CCD camera, NTSC / PAL switchable, support night flight.
 2205-2300KV Brushless Motor
KV : 2300
NO.OF cell : 2-4S
Framework : 12N14P
Shaft diameter: M5
Propeller :  5 inch
Weight: 29g
Blheli_S 20A ESC
Con.Current : 20A
Peak Current(s) : 35A
Input Voltage : 2-4S
BEC: No
Firmware : Blheli_S
Size(PCB) : 26*13.2mm
Support Dshot300 Dshot 600
Video TX
5.8G 600mw 32ch Transmitter build-in OSD.
Compatible: Eachine VR007 Pro, Eachine VR D2 pro, Goggles Two, EV800
Camera
Image: 1000TVL CCD
System: PAL / NTSC switchable
Power output: 5V
Camera can be adjusted upwards for 25°.
Supports night flight
Flight Controller
F3 6DOF, cleanflight 1.13.0
1100mAh 4S 14.8V 30C Lipo battery
Capacity(mAh) : 1100
Cells (s): 4
Discharge rate: 30C
Weight (g): 118g
Length(mm): 70
Width(mm): 22
Height(mm): 32
Connector: XT60
LED
Headlight LED: white 3W
Taillights: Seven-color highlight adjustable
5048 3-Blade Propeller
Material: PC
Color: red
Mounting hole: 5mm
Eachine I6 2.4G 6CH Remote Control
Channels: 6 Channels
RF Range: 2.40-2.48GHz
Bandwidth: 500KHz
Band: 142
RF Power: Less Than 20dBm
Sensitivity: 1024
Low Voltage Warning: less than 4.2V
DSC Port: PS2;Output: PPM
Charger Port: No
ANT length: 26mm*2(dual antenna)
Weight: 392g
Power: 6V 1.5AA*4
Display mode: Transflective STN positive type, 128*64 dot matrix VA73*39mm,white backlight.
On-line update: yes
Model Memories: 20
Bandwidth: 500KHz
Band: 142
RF power: less than 20dBm
RF.receiver sensitivity: -105dBm
ANT length: 26mm
Weight: 6.4g
Power: 4.0-6.5V
i-BUS port: NO
Data Acquisition port: NO
1 x Eachine Racer 250 PRO FPV Drone
1 x Eachine I6 2.4G Transmitter
1 x Eachine I6 2.4G Receiver
1 x F3 6DOF flight controller
4 x Blheli_S 20A  ESC
2 x 2205-2300KV motor CW
2 x 2205-2300KV motor CCW
4 x 5048 3 Blade propeller CW
4 x 5048 3 Blade propeller CCW
1 x mushroom antenna
1 x 4-cell 14.8V Lipo balance charger
1 x 1100mAh 4S 14.8V 30C lipo battery
1 x tail light LED colorized
2 x headlight LED white 3W
1 x 1000TVL camera
1 x 600MW 5.8G 32CH transmitter built in OSD
1 x remote control strap
4 x AA Battery
1 x battery strap
Cet article NEWS: Eachine Racer 250 pro ( Blheli_S/Dshot 20A, F3+OSD, 1000TVL CCD , 600mW 32CH) est apparu en premier sur Drone-Maniac !!!!!!!.
