NEWS: Eachine TX801 a 72CH 5.8G VTX with switchable output power
Probably the best compact 5.8G VTX: https://www.banggood.com/Eachine-TX801-5_8G-72CH-0_01MW5MW25MW50MW100MW200MW400MW600MW-Switched-AV-VTX-FPV-Transmitter-p-1147691.html; A 72CH variant with 8 choices of transmitted power: 0.01MW/5MW/25MW/50MW/100MW/200MW/400MW/600MW. 7.3g standalone. The module also provides a filtered from noise +5V for your camera module.
Description :
Brand Name : Eachine
Item Name : TX801 Transmitter
Antenna Gain: 3Dbi
Antenna Conenctor : RP-SMA
Frequency: 5325-5945MHZ
Channel : 72CH
Transmitting Power: 0.01MW/5MW/25MW/50MW/100MW/200MW/400MW/600MW Switchable
Video Format: NTSC/PAL
Working Current: (MAX)7V-550mA; 12V-300mA; 24V-160mA”
Audio Bandwidth : 6.5MHZ
Video Bandwidth: 18MHZ
Audio Carrier : 1Vp-p(1KHZ)
AF Input Impedance : 10KO
Working Voltage : 7-24V
Output Voltage : 5V
Weight :7.3g
Cable :
Blue : GND
Yellow : Video
Red : Output Voltage
Features :
8 power levels switchable: 0.01MW/5MW/25MW/50MW/100MW/200MW/400MW/600MW
72 channels, cover all 5.8G frequency.
With Microphone, support audio transmission
5V output, max working current 550mA
Multi-channel synchronization does not interfere with each other
Package Included :
1 x TX801 Transmitter
1 x Antenna
1 x Power AV Cable
Cet article NEWS: Eachine TX801 a 72CH 5.8G VTX with switchable output power est apparu en premier sur Drone-Maniac !!!!!!!.
