NEWS: Hawkeye Firefly 8S (Ambrella A12S75, SONY IMX117, 4K@30fps, 1080p@120p)
The new upgrade of the Haweye Firefly action cam camera is announced: https://www.banggood.com/Hawkeye-Firefly-8S-4K-170-Degree-Super-View-Bluetooth-WiFi-Camera-HD-FPV-Sport-Action-Cam-p-1148676.html
It’s including the last ambrella A12S75 DSP and the SONY IMX117 12Mpx CMOS sensor to deliver 4K@30fps, 1080p@120, the super-view (kind of super WDR) and a better electronic image stabilization. A rear large VGA screen is present and 2.4G and bluetooth wireless connexion included too. The total weight is about 70g. Can be a nice upgrade for UPair one drone.
Brand Name: Hawkeye
Item Name: Firefly 8S camera
Photo Resolution:16M/14M/12M/8.3M/5M/3M
Video Resolution: 4K/30fps, 1080P/120fps, 1080P/60fps Super-view, 720P/120fps
Image Sensor: 12 Mega WDR CMOS Sensor
AV Output Format : PAL/ NTSC
Working Voltage: 5V
Power supply: 1A
Maximum size of MicroSD card supported: 128G
LCD screen size: 2 inch 640*480
Battery Capacity (Battery is detachable): 1200mAH,3.85V
Battery life: About 1.33 hours(25? environment)
Compressed format : H.264
Video/photo format : *.MP4 / *.JPG
Weight: 70g
Size: 59 × 41 × 21 mm
Color:Black/Silver
Feature:
1.Small, Light, HD camera.
2.Top-level Image Sensor,producing very good Wide Dynamic Range imaging effect.
3.Low illumination performance.
Even in low light environment, FIREFLY 8S still presents good video quality and vivid color.
4.Six-axe Gyro video stabilization
Firefly 8S can produce very stable video image without losing any view angle.
5.Eight Quickset modes for capturing
Letÿs enjoy the unique design of eight quickset modes and start for fun.
6.Bluetooth 3.0
A small Bluetooth remote controller is designed for you to wear on your wrist or tie to the selfie stick, now you can capture photos/videos more easily.
7. External microphone
With a high quality external microphone (not included in the standard package), you can record a higher quality voice.
8. 2.4G WiFi
Connect it to your mobile phone via WiFi, you could easily share your photos.
9. Brand new APP
You can modify most of the setting and update your camera through the APP.
10. 2 inch high brightness LCD
Brightness adjustable LCD screen adopted to make it bright enough under sunshine and not too bright at night.
11. 1200mah detachable battery
FIREFLY 8S goes with a new type 3.85V battery and the battery life is up to 1.3 hours.
12. 170 degrees wide angel lens and 90 degrees linear lens
170 degrees for actions and 90 degrees for family filming.
13. Waterproof case and accessories
We test every waterproof case and provide multiple accessories for you to have more fun.
14.RC Remote control
You could remote control to capture videos/photos through RC receivers by using the Hawkeye remote control cable.
15.Selfie Mirror
The unique design of selfie mirror will help you selfie more accurate.
16.1/4 inch Screw and lanyard hole
These thoughtful design will help you carry the camera every. We always think small and think different.
1 x FIREFLY 8S 4K Super-View HD Camera
1 x Waterproof Case
1 x J-shaped Mount
1 x Long Connector + Screw
2 x Short Connector + Screw
1 x Bike Handlebar Seatpost Pole Mount
1 x 360 Degree Rotation Adapter
1 x Metal Cable Tie
4 x Plastic Cable Tie
1 x Cleaning Cloth
1 x Clip and Case
1 x AV Cable
2 x Mount
2 x Adhesive
1 x English / Chinese Manual
Already first video samples are available
Cet article NEWS: Hawkeye Firefly 8S (Ambrella A12S75, SONY IMX117, 4K@30fps, 1080p@120p) est apparu en premier sur Drone-Maniac !!!!!!!.
