Cheerson introduces with CX-23, a kind of FPV brushless cruizer equiped of GPS: https://www.banggood.com/Cheerson-CX-23-CX23-Brushless-5_8G-FPV-With-720P-Camera-OSD-GPS-RC-Quadcopter-RTF-p-1149089.html. The design presents a small originality with inverted rear props. The flight controller is probably a non-open one so with fixed settings. Motors 1306/3300 Kv. No indication about ESC but the general setup is powered with a 2S 1200mAh LiPo. The FPV camera can record 720p videos. Unfortunatly, the FOV seems relatively narrow, IMHO maximum of 90 degrees, probably less 🙁 … It will be difficult for FPV applications. Good news, some telemetry informations are sent to the radio such as battery voltage, GPS informations, speed. This RTF bundle comes with a 4.3″ 5.8G FPV monitor. Both the control and the FPV ranges are advertized to be around 500m and 14min for the flying duration.
Brand Name: Cheerson
Item NO.: CX-23
Color: Black
Blades diameter: 120mm
Quadcopter battery: 7.4V 1200mAh
Quadcopter battery charging time: about 150mins
Flying time: about 14mins
Transmitter working frequency: 2400-2483GHZ
Transmitter battery: 5V 2000mAh
Transmitter charging time: about 150mins
Transmitter using time: about 80mins
Transmitter charging current & voltage: 1A 5V+
Camara: 2 mega pixel
Picture resolution: 1920*1080
Picture format: JPG
Video resolution: 1280*720
Video format: avi
FPV monitor: 5.8G 4.3inch monitor
Motor type: 1306 KV3300 brushless motor
RC distance: about 500m
FPV distance: about 500m
Flying height: about 100m
Largest ascending speed: 5m/s
Largest descending speed: 5m/s
Largest flying speed: 10m/s
Product size: 245*245*90 mm
Product weight: 230g
-It has OSD function that the transmitter can show the height, number of satellite, flying direction, speeds and battery level etc. of the drone at the same time.
-It has low-voltage warning and low-voltage auto landing function which improves the safety problem.
-7.4V 1200mAh battery with inserting structure that the flying time is longer and the installation of battery is fast.
-It can do one touch return and out-of-control return which prevents disappearing. Camera is together with video transmitter and it is convenient to control it
-It can do around flying that you can control it to fly around with a certain radius .Brushless Motor strong power to the quadcopter.
-It has the functions of forward/backward, left rotation, right rotation, turn left/right, one touch take-off, one touch landing, height hold and point hold, auto return etc.
1 x Cheerson CX-23 quadcopter with camera
1 x Transmitter
1 x 7.4V 1200mAh LiPo Battery
2 x Spare Blade
2 x Landing Skid
1 x Screwdriver
1 x Charger
1 x USB cable
1 x Propeller fixing mount
1 x Manual
Cet article NEWS: Cheerson CX-23, a 5.8G brushless cruizer with GPS est apparu en premier sur Drone-Maniac !!!!!!!.
