NEWS: Quattrovolante Q-Carbon49 frame (49mm frame for 16mmx16mm FC, 0703 motors)
Smaller and smaller …. Quattrovolante, an italian compagny will introduce a 49mm frame: http://www.quattrovolante.com/Fabry/product/q-carbon49-frame/
1.5mm 3K carbon main plate.. but ABS or TPU (3D-printed) camera pod. Compatible FC must be 20mmx20xmm max with 16mmx16mm holes. Some recent FC and 4-in-1 ESC board are now compatible with such microsize… No prop guard of course. 31mm quadriblade props are advised. 0703 motors 12000 or 20000 Kv are also adivsed (like the Eachine DustX58)
QuattroVolante Q-Carbon frame 49mm
– Same spcs of Q-Carbon 56 with shorter arms and smaller props (max 31mm with hole bored to 1mm)
– This item is in preorder, will be shipped from the 2th week of May
– 1.5mm thick 3K Carbon fiber main plate, ABS or TPU pod
– The FC is fixed on a TPU mount and is not directly screwed to the frame for smooth, vibrations free, flights
– Suggested brushless motors: 0703 12000-20000KV with 40mm propellers
– The kit is designed and optimized to use 20mm (16x16mm holes) fc and same size 4in1 esc
– Maximum size for propellers is 31mm
– Fits small AIO cameras (max 16.5x9mm)
– Carbon fiber prop guards will be available soon
– Motors and electronics not included
Cet article NEWS: Quattrovolante Q-Carbon49 frame (49mm frame for 16mmx16mm FC, 0703 motors) est apparu en premier sur Drone-Maniac !!!!!!!.
