NEWS: SPC-95X (94g,F3+OSD,3S 350mAh,1104/7500Kv, 25mW/48CH/600TVL AIO)
Every week is announced a new 90-100mm brushless racer. Here is the new SPC-95X: [https://www.banggood.com/SPC-95X-95mm-FPV-Racing-Drone-BNF-w-OSD-Ominibus-F3-10A-BLheli_s-5_8G-25mW-48CH-VTX-p-1149169.html
As for the other, you have a F3 board including a builtin betaflight OSD, a mini 4-in-1 10A ESC BLheli_S/Dshot600 ready compatible accepting up to 4S battery, 1104/7500 Kv motors so definitively 3S compatible. The 5.8G FPV job is done by a 25mW 48CH CMOS AIO FPV camera… Three choices of receiver are proposed: Futaba SFHSS, FrSky D8 and Spektrum DSMX/DSM2. The main difference with other models is the direct introduction of a 3S LiPo. The frame seems super solid, at least 2mm of thickness. 4-5min of flight time are promised with the 3S LiPo…
Brand name: SPC Maker
Product model: SPC 95X
Wheelbase: 95mm
Weight: 63g (without battery)
Flight weight: 96g(Include battery)
Motor: SPC Maker 1104 7500KV brushless motor
ESC: Mini 4 in 1 BLheli_s ESC (2-4S LiPo)
Propeller: 50mm 4-blades propeller
Receiver: Receiver: Frsky/DSM2/Futaba(optional)
Camera: 600TVL HD CMOS 1/4 inch
VTX: 5.8g 25MW 48CH NTSC/PAL Video transmitter
Flight controller: OSDOminibus F3 flight controller integrated with OSD module
OSD: Betaflight OSD
Firmware of flight controller: Betaflight_3.1.0_OMNIBUS
Flight time: 4-5minutes
Rear LED Ready( LED_Strip function)
Buzzer Ready
Battery: 11.1V 350mAh 80C lipo battery
Flight controller parameters:
Ominibus F3 flight controller integrated with OSD module.
1.Powered by MPU6000 sensor for quick response to acceleration, integrated with 5V/1A BEC and OSD module (This is 6DOF version, no barometer and compass).
(1) Designed for small size FPV quads with a frame smaller than 280mm, especially ideal for quadcopters smaller than 130mm to exhibits its advantages in small dimensions and multiple functions.
(2) It provides all the functions of F3 6DOF version, but weighs only 8 grams. The size is only 27*27mm. Mounting hole size is 20mm (2.5mm hole).
(3) Designed for quadcopter with LC filter. It supports CF and BF firmware (Omnibus F3)
(4) STM32F3CCT6 microprocessor, 256K memory, MPU6000 sensor, SPI port, faster processing speed.
(5) Supports 2-4S LiPo input.
(6) Built-in 5V 1A BEC.
(7) Supports popular receivers such as SBus, PPM, DSMX.
(8) Buzzer, programmable LED, voltage monitoring, HLHeli ESC.
4 in 1 BLheli_s ESC
Input voltage: 2-4S LiPo and 2-4S HV LiPo
BEC Output: Not available
Constant current of a single ESC unit: 10A
Maximum current: 15A 5 second.
Dimensions: 27*27mm (main board)
31*31.5mm (including soldering pads and extruded part)
Weight: 6.3g
Firmware: BLHeli_s
Supports D-Shot, Oneshot, rotation directions.
Processor: SILABS EFM8BB21F16G
MOS FET: TPN2R703NL
Driver: new generation 3 in I MOS
Specification of Mini F3 flight controller tower:
Weight: 8g
Supported frames: smaller than 280mm
Constant current: 10A*4 (maximum current: 15A*4, 5s)
Camera VTX parameters
Frequency band: 5362-5945MH
Channel: 48
Modulation type: FM
Select channel: switch
Channel display: CH1-CH8 channel display with 8 LEDs, and A-F frequency group display with 6 LEDs
Transmit power: 13±1dBm
Frequency control: PLL
All harmonic: Max-50 dBm
Frequency stability: ±100KHz(Typ.)
Frequency precision: ±200KHz (Typ.)
Channel disk failure: 1dB
Antenna port: 50 O
Input format: NTSC / PAL
SENSOR: PAL: 720 × 540/NESC: 640 × 480 1/4 ”
LENS ANGEL: H: 120 ° / V: 100 °
Baseband interface: P1, 27 * 2
Energy consumption: 200-215MA@5V DCIN
Supply voltage: 2.9-5, 5V
Operating temperature:-10? ~ + 60?
Profile dimension: 14, 5 mm × 12, 2 mm + 14, 5 mm × 12 mm
Compatible
1.DSM2 Receiver Support Spectrum/JR(DSM2 protocol) DEVO10/DEVO 7E(with deviation firmware).
2.Compatible Frsky Receiver Support FRSKY taranis X9D/X9D PLUS(D8 mode),and XJT (D8 Mode),DJT DFT DHT Transmitter.
3.Compatible Futaba Receiver Support TM7,TM8, TM10, TM14 T6EX-2.4G,7C-2.4G,T8FG,T10CG ,T12FG.T14SG.
Receiver Setup and Binding Methods
Quads with DSM2 Compatible Receivers
Binding method for Spektrum radios:
1.Push and hold gold button on top of flight controller.
2.Plug in battery.
3.Release button, light will flash quickly.
4.Hold radio away from machine.
5.Put radio in bind mode.
You are done!
Quads with FrSky Receivers
Binding methods for FrSky radios:
1.Select the D8 mode in X9D radio, and hold binding button of receiver at the time of powering it on. The LED should stay in solid. Then select ÿBINDÿ in radio. Binding is successful if the LED light of receiver goes off. Release binding button and power off receiver to exit binding mode. Receiver is ready to use after powered on.
2.For DJT and DFT modules, hold the button on module and power on radio, and the module is set in binding mode. Press and hold the binding button on receiver then power it on. Binding is completed if LED light goes off. Release binding button and restart receiver, and the system is ready for use.
3.For XJT module please select D8 mode by using the dip switch, and follow the above binding procedures.
Enable PPM output:
Short the solder pads of PPM on receiver board to enable PPM output. This can be used for flight controllers, wireless simulators, and wireless trainer radios.
Enable s.Bus mode:
Short the solder pads of s.Bus on receiver board to enable s.Bus output.
Failsafe setup:
Failsafe is assigned to channel 3 only, and cannot be defined by users. No matter what mix setup is used, please make sure throttle is assigned to channel 3.
Quads with Futaba Compatible Receivers
Binding method for Futaba radios:
Compatible with Futaba radios support FASST.
1.Set the radio to FASST mode. Hold the binding button on receiver and then power it on. The red LED should flash rapidly. Release binding button the LED should flash red and green alternately, and then turns to solid green to indicate a successful binding. It may requires several trials to complete a binding. A solid red LED indicates the binding is not established.
2.Fail safe can be setup in the radio, and can be set after binding process. Hold the binding key for 2-3 seconds, the LED indicator of failsafe will flash rapidly and then turns to solid green, indicating it is in fail safe mode.
Package include:
1 x SPC Maker 95X Frame
1 x Ominibus F3 flight controller integrated with OSD module
1 x Compatible Frsky/DSM2/Futaba(optional receiver)
4 x SPC Maker 1104 7500KV brushless motor
1 x Mini 4 in 1 BLheli_s ESC (2-4S LiPo)
4 x 50mm 5-blades propeller CW
4 x 50mm 5-blades propeller CCW
1 x 600TVL HD CMOS 1/4 inch camera
1 x 5.8G 25MW 48CH NTSC/PAL VTX
1 x 11.1V mAh 80C lipo battery (comes without charger)
1 x WS2812 LED Board
Cet article NEWS: SPC-95X (94g,F3+OSD,3S 350mAh,1104/7500Kv, 25mW/48CH/600TVL AIO) est apparu en premier sur Drone-Maniac !!!!!!!.
