Was expectable since Eachine are renewing all their goggles by integrating now a builtin DVR… Now it’s the turn of the excellent EV900 with the D version: https://www.banggood.com/Eachine-EV800D-5_8G-40CH-Diversity-FPV-Goggles-5-Inch-800480-Video-Headset-HD-DVR-Build-in-Battery-p-1150119.html
Not only a full D1 PAL bultin DVR is added, but also the diversity !!!! You still have this possibility to split the goggles in two and the resolution remains a 800×480, so you can’t perfectly display a PAL source (720×576). The goggles chassis remain the same … a pretty good one, confortable enough. But No Fresnel lens distance ajustement 🙁 ..anyway, the screen is compatible with average myopia and the mask opening is compatible with glasses. The price is still attractive. The 2000mAh 1200mah builtin is advertized to offer close to 2h of usage… It’s pretty good… The builtin receivers are coupled with a circular RHCP (proximity range) and one hi gain biplanar antenneas (long range). The built PAL D1 (720×576) recorder is also announced to not have any frame lost…but quid about extra latency introduced when recording is turned on ? They announced two seperate chips for solve this problem… Must be checked in practice of course …. What about NTSC sources recordings (756×480) ? You have an AVin latterally.. Full OSD informations seems here … as well as a lot of screen ajustement settings via the menu.
Built-in with super HD DVR record up to 720*576px resolution
Diversity RaceBand 40ch Auto-Searching
Two systems (Display/Record duo core separated chipsets ) ensure no delay in displaying and no frame lost in recording(please use C10 super speed card to ensure the full frame recording)
Work friendly with pilot-OSD, no block on the important flying OSD information;
Separable design, 5 inch screen can be used as small monitor on radio controller or with tripod;
HD high brightness 5 inch LCD specially tuned for FPV racing;
Diversity function, Built-in super sensitive 5.8GHz 40ch receiver module, with RaceRand;
Advanced auto-searching function and the working frequency show on screen;
Built-in 7.4V 1200mAh battery, each full charge offer 2 hours working time;
Wide range re-charge voltage 11-20V;
Accept 2S or 3S batteries as back-up power source, to prolong the working time;
Nice ergonomic design and fit different faces;
Super-wide visible angle up to 82 degree;
92% transparent lens adopted, no distort, no blur on the edge of screen;
Light weight 375g with 3.5 hr 2000mAh battery, RTF for any scale racing game;
5 Inch 800*480px HD high brightness LCD
Package Included :
1 x EV800D 40CH 5.8G Diversity Goggles with DVR
1 x Clover Antenna
1 x Panel Antenna
1 x Battery Charger
1 x User Manual
1 x Clean cloth
1 x Bag
Cet article NEWS: Eachine EV800D 5.8G 40CH 800×480 with Diversity and builtin DVR est apparu en premier sur Drone-Maniac !!!!!!!.
