After the super original compact mini brushless 3D FPV RealAcc Horns 100, RealAcc (Eachine deluxe devision) will introduce another super original design, a Y4 design: https://www.banggood.com/Realacc-Scops-100-Micro-Y4-FPV-Racing-Drone-BNF-w-F3-OSD-10A-BLheli_S-Dshot600-5_8G-25MW-48CH-VTX-p-1152996.html
It’s not a tricopter since you have this fourth upside down brushless motor and not an Y6 since front motors are not doubled. Really an original design. First thing, this machine now comes directly in 3S setup thanks to the 1104/6500Kv motors (slower so 3S capable). The main electronic is based on the Eachine Minicube, so a F3 omnibus integrating a betaflight OSD, a 4-in-1 10 ESC BLheli_S/Dshot600 ready. The FPV rig is based on the classic 600TVL 1/4th CMOS FPV camera coupled with a 25mW 48CH VTX. Four choice of BNF versions are proposed: FrSky D8+RSSI, FrSky D16 w/ smart port, FlySky AFHDS-2A and Spektrum DSM2/DSMX. I don’t know if the Y4 design is a real plus in term of flight caracteristic…. but at least it’s original. THanks to the 3S 550mAh with XT30 connector (the same as for the Eachine Lizard 95), the flight time are advertized to be abount 3-5min (huge standard deviation 🙂 )
Brand name: Realacc
Item name: Scops 100 Micro Y4 FPV Racing Drone BNF
Weight: 66g (battery not include)
Flight controller: Minicube Betaflight F3 Flight controller built-in OSD
Motor: Realacc 1104 6000KV brushless motor
Propeller: 50mm 5-blades propeller
Camera: 600TVL HD CMOS 1/4inch
VTX: 5.8g 25MW 48CH NTSC/PAL vdeo transmitter
Battery: 11.1V 550mah 40C lipo battery
Flight time: 3-4minutes
Buzzer Ready
BNF receiver option:
Compatible Frsky D8 mode SBUS receiver (RSSI ready)
Original Frsky D16 mode SBUS receiver (Smart port ready)
Compatible Flysky 8ch AFHDS2A receiver Ibus output with Failsafe
Compatible Specktrum DSM2/DSMX receiver
Minicube Betaflight F3 6DOF Flight controller built-in OSD 2-3S:
Mount hole: 20mm*20mm
Processor: STM32 F303 MCU
Sensor: SPI Sensor MPU6000
Built-in Betaflight OSD (Batt voltage, RSSI, Artificial Horizon, Fly mode, Flytime, Craft name etz.)
Firmware version: Betaflight 3.1 Dshot600 ready
Target: OmnibusF3
OSD: Betaflight OSD
Work voltage: 2S-3S lipo battery
Minicube 4 in 1 10A ESC BLHELI_S 16.5 2-3S:
Firmware version: BLHELI_S 16.5
BB2, 48MHZ Chip
Lipo Battery: 2S-3S
Con. Current: 10A
Peak Current: 15A (10S)
BEC: 5V @0.1A
Programming: YES
Betaflight pass-trough ready
Dshot600 ready (Default)
Support oneshot42 oneshot125 Multishot Dshot
Damped light on
Y4 Frame with Betaflight firmware support.
Extremely light and more powerful.
STM32 F303MCU + BLHELI_S ESC make your operating feel more stabilly and silky.
Adjustable angle of camera
Jaw-dropping flight performance
Acro mode / Air mode / Angle mode support.
Built-in OSD (Using F3 MCU controls OSD over SPI bus in DMA mode).
OSD configuration has been include in BETAFLIGHT GUI.
Radio Stick to control PID Tunes.
BLEHELI_S pass-through ready.
Telemetry RSSI Output ready.
1 x Realacc Scops 100 Frame kit
1 x Minicube Betaflight F3 6DOF flight controller build-in OSD
1 x Original Frsky D16 receiver / Compatible Frsky D8 / DSM / Flysky AFHDS2A Receiver (optional)
4 x Realacc 1104 6000KV brushless motor
1 x Minicube 10A BLHELI_S 16.5 2-32S 4 in 1 ESC Dshot600
4 x 50mm 5-blades propeller CW
4 x 50mm 5-blades propeller CCW
1 x 600TVL HD CMOS 1/4 inch camera
1 x 5.8g 25MW 48CH NTSC/PAL VTX
1 x 11.1V 550mah 40C lipo battery
1 x Buzzer (integrated in receiver)
Cet article NEWS: RealAcc Scops 100, a first Y4 micro brushless FPV racer est apparu en premier sur Drone-Maniac !!!!!!!.
