Want a super light FPV camera with low latency able to record in 1080p ? Have a look the new Runcam Split: https://www.banggood.com/Runcam-Split-1080P-DVR-FPV-Camera-WithWithout-WiFi-2_5mm-FOV-130-165-Degree-NTSC-PAL-Support-64G-TF-p-1159850.html
The originality is the two different FOV, 130 degrees in 4:3 for the FPV part, and 165 degrees in 16:9 for HD recordings. You can record up to 1080p@60fps. Low latency is promised but no real value is given.
A total of 21g is announced so clearly much lighter than a runcam HD2 for example… more you are saving also the weight of the FPV cam. If the latency is below 40ms even when recording is turned on… could be a super product from 120mm machines.
Description :
Brand Name : Runcam
Item Name : Split RunCam 3
FOV Angle of Field FPV FOV 130° / Recording FOV 165°
Video Resolution 1080@60fps / 1080@30fps / 720@60fps
Video Files MOV
Image Resolution 2 Megapixels
TV Output NTSC / PAL Switchable
Real-Time Audio Output Yes
Interface Micro USB / UART
Max Micro SD Card Supported 64G(need Class 6 or above, recommend Class 10/UHS-I/UHS-II)
WiFi Module Support (Removable)
Dimensions PCB 36*38mm / Lens Module 22*20mm
Power Input DC 5V
Working Current 650 mAh
Weight 21g
Features :
HD recording, same effect as Runcam 3
Supper WDR FPV image with low latancy
Recording and FPV can do at the same time
26g super light
Camera + Board split, main board and FC can be installed on frame kit, camera is same as mini Swift.
Lens is removable
WiFi module is optional, support APP setting and previewing on mobile.
Package Included :
1 x Runcam Split Camera
1 x Mounting Bracket Pack
1 x Cable Pack
Cet article NEWS: Runcam Split (4:3 FPV and 16:9 1080p@60 dual FOV camera) est apparu en premier sur Drone-Maniac !!!!!!!.
