Want a cheap and lightweight AIO FPV camera module ?. Maybe this new model (unbranded ?) can be interesting: https://www.banggood.com/5_8G-25mw-48CH-Transmitter-700TVL-OSD-Wide-Angle-FPV-Camera-NTSCPAL-p-1164450.html
120 degrees, 3.7g … and compatible with OSD systems. No information about the light senstivity but it’s based on a 700TVL CMOS camera. A simple linear antenna in order to save some weight. Can be the perfect compagnon of your TinyWhoop system.
Frequency: 5.8G 48CH
Resolution: 700 TVL
Pixel: 5 million
Power: 25MW
Voltage: 5V
Current: 180MA
Signal system: PAL/NTSC ( Autoadaptation)
Lens: H:120 degrees /V:100 degrees
Power indicator: LED
Channel carrier power difference: 1DB
Omnidirectional drop antenna impedance: 50 0hms
Volume: 14x11x6mm
Net weight: 3.9g
1.This transmitter camera is compatible with OSD.
2.700TVL high picture quality,Low Power Consumption.
1x Transmitter module
1x Wide angle lens camera
1x Antenna
1x Cable
1x Power interface
Cet article NEWS: 700TVL/120 degrees 25mW 48CH 3.7g AIO FPV camera est apparu en premier sur Drone-Maniac !!!!!!!.
