Remember my last review of the excellent Boldclash F-08 ? . Here is more or less the same module from Turbowing: https://www.banggood.com/Turbowing-DVR-CYCLOPS-3-DVR-VTX-CAM-AIO-700TVL-5_8G-48CH-0mW25mW200mW-FPV-AV-Transmitter-Camera-p-1181449.html
You will have the same DVR recording files in 720x480p resolution @30fps but this module seems smaller in dimensions and can output up to 200mW. In the other hand, the total weight is 7.2g so 1.6g more heavier than the F-08. This new module targets more compact micro FPB brushless machines. The camera part is based on a 700TVL 1/3″ sensor so should have better light sensitivity. The FOV around 110deges. 48CH channels for the VTX part.
Description
overall Brand name turbowing
Item NO 5.8G DVR VTX
Item name cyclops dvr 3
size Camera 18*18*8mm+Transmitter 18*23.2*3mm
weight Camera:4.5g +Transmitter:2.7g=7.2g
FPV DVR Camera
output voltage 4.2V
Sensor size 1/3 ”
Camera Resolution 700TVL
Lens M7 Lens
Angle H:120 ° / V:100°
Operating Temperature -10 °~+60 °
Input format NTSC PAL
Audio In addition it comes with a built in microphone
MicroSD Max 32G
record 720P HD
Record Status Working LED : 1 Red LED on
Press the video button to start recording. You will see a red flashing led “00:00:00” on the screen that changes from white to red. Red indicates that the camera is recording.
Transmitter Output power 0/25mw/200mw switchable
(25mW: 14dBm 200mW: 23dBm)
Supply voltage 5-16V
Current consumption 0 mW: 90mA@12V
25mW: 130mA@12V
200mW: 250mA@12V
antenna 5dbm
Frequency band 5362~5945MHz
Channel customer 48
Channel SEL Touch Switch
Channel Indicate CH1-CH8 Channel indication with 4LEDS and frequency group indicate with 3LEDS
Input format NTSC
Power memory function The last selected power level can be saved automatically
Battery Battery 5-16v(1s-4S lipo Battery)
Package Included
1 X DVR recorder& camera
1 X Power supply, CVBS cable
1 X 5.8G DVR FPV Camera
1 X Cable
1 X 0/25mw/200mw Transmitter
1 X Cable
Cet article NEWS: Turbowing Cyclop 3 4-in-1 AIO DVR FPV module est apparu en premier sur Drone-Maniac !!!!!!!.
