NEWS: Eachine R051 150CH 5.8G receiver for both iOS & Android devices
A new external 5.8G 150CH receiver with OTG connexion for both Android & iOS devices !!!!: https://www.banggood.com/Eachine-R051-150CH-5_8G-FPV-AV-Recevier-Build-in-Bat-For-iPhone-Android-IOS-Smartphone-Mobile-Tablet-p-1196214.html
The RX sensibility is “only” -90dBm. A unique button to scan all the 150CH. I hope there will be some OSD informations displayed to have an overview of all the 150CH.
Specification
Channel : 150CH
Freqency : 5645~5945
Receiving Sensitivity : -90dBm
Working Current : 350mA
Working Temp. : -10°~60°
Battery Capacity : 400mAH
Weight : 36g with antenna
Size : 55mm x 36mm x 15mm
Interface
1. Switch : Power ON/OFF
2. Channel Button : Switch and Search Channels
3. Toggle Switch : Support to switch IOS/Android smartphone
4. Micro USB Port : Connecting IOS/Android Smartphone
5. Antenna : 5.8G wireless signal input
6. Indicator : Blue LED represents IOS mode;Green LED represents Android mode;Red LED represents low battery and charging mode.
ON/OFF
1. Long press switch button for 3S : switch on(IOS Mode, blue LED on; Android Mode, green LED on)
2. Long press switch button for 3s : LED off, switch off.
3. If there is no device input, it will automatically turn off after 3 minutes.
Auto Search Setting
1. IOS/Android Mode : Long press the channel button for 3S, to enter into the auto search mode, Blue LED
(IOS)/Green LED(Android) flashes. After the auto search finished, LED is constant, and it will switch to the channel of strongest signal.
2. It will display the signal strength and frequency on smartphone while auto searching.
3. It can save the last channel setting.
Channel Setting
1. IOS/Android Mode : Each time you press the channel button ,the channel increases by 2MHz, Blue LED
(IOS)/Green LED(Android) flashes once.
2. It can save the last channel setting.
Battery Indicator
1. Red LED flashes slowly : Low battery, the receiver will switch off after it flashes about 3 minutes
2. There is a battery power icon on bottom right of smartphone, will flashes when it is in low battery.
Charging
1. It must be switched off while charging
2. While charging, red LED flashes; after charing finished, red LED shows constantly
3. After swithed off, please disconnect with smarphone. Because the android smarphone will charge it while it is off.
Note
1. The channel frequency, signal strength and dynamic diagram will not displayed untill you press or long press “searching button” to enter into the auto searching function. And these information will be hidden 10s later.
2. The icons of Channel frequency, signal strength and power will display constantly on bottom right of video, these information will refresh each 10s.
3. The connection of android and IOS mobiles are different, please check pictures on page.
Package Included
1 x Eachine R051 150CH Receiver
1 x USB A Female to Micro USB Male Cable
1 x SMA Antenna
Cet article NEWS: Eachine R051 150CH 5.8G receiver for both iOS & Android devices est apparu en premier sur Drone-Maniac !!!!!!!.
