Want a super light DVR to plug to your favorite Goggles mask/binocular ? Or to record in clean condition the direct raw output of your FPV camera ?Have a look to the shrinked version of the HMDVR “S” version: https://www.banggood.com/HMDVR-S-DVR-Video-Audio-Mini-FPV-Recorder-for-Micro-FPV-Multicopters-p-1208562.html
The module is annouced to weight 5g with the plastic casing … probably around 3-4g without…. One unique button to start/stop recording so no playback functionalities. Notice whatever a NTSC/PAL source, everything is downscale to 640×480 resolution…. So I really hope no specific cropping is added. One unique 4 position port for GND, +VCC, Vin and Audioin…. The module accepts voltage from [3.6V-5.5V]…. so maybe at very low 1S voltage, the module will stop to work. From 2S, you will need a voltage Step down
Description
Item name: HMDVR-S DVR Video Audio Recorder for Micro FPV Multicopters
Weight:5g
Power Supply :  5.0v (3.6V-5.5V)
Current Consumption: Max 260mA.
Operating Temperature: -10~+65 ºC
Video  Output  Size: VGA (640×480)
Video output formats: NTSC/PAL
Light  frequency: 50HZ/60HZ
Compress Format : MJPEG
Records the picture frame rate: 30Frames
Audio input :  support Micphone input
TF Card support: Max.32G
Interface: JST SH1.0 or 1.25 pin headers
Package Included
1 x DVR
Cet article NEWS: HMDVR “S” Mini, a 5g DVR module est apparu en premier sur Drone-Maniac !!!!!!!.
