Between a plane and and a multirotor, Vtol (Vertical Take-Off Landing) machine starts to become popular especially thanks to new flight controllers managing now correctly transition between vertical to horizontal positions.
Here is the new XK “Sky Wizzard F-500”: https://www.banggood.com/XK-SKY-WIZARD-F500-VTOL-Vertical-Takeoff-And-Landing-3D6G-FPV-EPP-RC-Airplane-RTF-p-1210336.html
This new XK model (deluxe devision of WLtoys) includes its 3D6G flight controller with three specific flight mode: one more for indoors application where the machine is vertical and is controller more like a quadcopter, the second more for outdoors and the machine is more similar to a plane and the last one so-called “stunt mode”.
The machine is equiped of two brushless motors and is powered by a 2S LiPo. As for most XK models, the associated radio protocol is compatible with the Futaba S-FHSS (Jumper compatible too). I would like to test such kind of machine…I never flew one… Can be interesting.
Brand name: XK
Item number: XK SKY WIZARD F-500
Wingspan: 520mm
Flying time: 15min
Charge time: 50-60min
Transmitter: 2.4G transmitter
Remote control distance: more than 150m
Motor: 1307 *2 ( Brushless )
Battery: 7.4V(950MAH) 20C
– 1307 brushless motor, 2.5g high-precision digital servo, flight distance of 150 meters or above.
– With 2.4GHz comminication technology,can be compatible with FUTABA S-FHSS
– 6-axis gyroscope, 3D / 6G mode conversion, suitable for different scenes of flight, more suitable for beginners to practice flight.
– Multirotor versatility and sport plane agility
– Takes off and lands vertically in small areas
– Fly slow or fast and perform aerobatics in airplane mode
– Can be hand launched and belly-landed like a conventional wing
– 3D6G technology makes VTOL flying easy
– Outstanding speed and climb performance
– Lightweight and extremely durable EPP airframe.
– The aircraft has multiple flight modes
1) indoor vertical flight, the aircraft can flying like a four-axis aircraft or helicopters, vertical flight, hover flight, forward, backward, left and right side fly, spin flight.
2) outdoor mode. The aircraft takes off vertically, one key switch, the aircraft will climb 3-5 meters and chang to horizontal flight automatically (6G self-stabilizing mode), just like a fixed-wing aircraft to control the aircraft climb down and turn around, suitable for beginners.
3) outdoor stunt mode, after The plane flew horizontally in the air, switching 3D / 6G key, the aircraft will get into 3D stunt mode (3D lock mode), Easy to make Somersaulting, Rolling, Death spiral, and other stunts.
– The front three points landing gear, can be used for the special case of glide landing, or outdoor glide takeoff, directly get into the fixed wing mode.
– Customers can choose 720P HD, 2.4G WIFI or 5.8G VTX, the camera angle is adjustable, vertical shooting and 30 degrees before and after shooting can be carried out.
1X XK SKY WIZARD F-500 VTOL 3D EPP FPV RC Airplane
1X Transmitter
1X Charger
1X CW CCW Propeller
1X Battery
Cet article NEWS: XK Sky Wizzard F-500, 2S brushless VTOL machine est apparu en premier sur Drone-Maniac !!!!!!!.
