F4 boards are only and spread since one year only and now F7 board are already in the corner: https://www.banggood.com/Omnibus-F7-V2-Flight-Controller-STM32-F745-MCU-2-4S-Built-in-Betaflight-OSD-Dual-Gyro-30_5x30_5mm-p-1215667.html
Not only CPU clock are one more time increased versus the F4 but now a dual 6-axis IMU is present to improve even more the stabilization’s performances. More, the gyro-accelero chips are installed on a dampening gel and should absorb any vibrations transmitted by motors. The F7 board is large (36mmx36mm) and weigths 10g so clearly for >130mm machines. With this board, no problem to push the machine up to 32Khz.
OMNIBUS F7 V2 now with inertial damping gyro jacket. The case mass absorbs & resists by inertial damping the vibrations coming from the motors, props, frame, ect… – The added crash protection. The case is mounted by Gell tape and not hard mounted to the airframe in the same way a normal gyro is isolated. In our testing this does work better then soft mounting the whole Flight Controller.
Item name: Omnibus F7 V2 flight controller
MCU: STM32 F745 (Spi connected to Gyro)
MPU6000 (the 6 axis SPI Gyrometer + Accelerometer)
IMC268 (the 6 axis SPI Gyrometer + Accelerometer)
D-shot Support
Dual Gyro
Baro
BF OSD
microSD
Blackbox
Mount holes: 30.5×30.5mm
Weight: 10g
Default firmware: betaflight_3.2.0_OMNIBUSF7V2
SBUS, IBUS, DSM2, DSMX Receiver configuration: UART2
F7 MCU – faster than the current F3 and F4 processors.
Two gyros on the flight controller: an MPU6000 for sampling up to 8khz and ICM20608 for sampling up to 32khz.
Built in betaflight OSD
36x36mm, mount holes 30.5×30.5mm.
SD card reader for recording black box data (SD card not included).
Supports 2-4S natively
5V/3A regulator
Port for easy connection to 30A 4-IN-1 ESC (SH1.0 8P)
1 x flight controller
1 x SH1.0 6P cable
1 x SH1.0 8P cable
Cet article NEWS: Flight Controller F7 Omnibus V2 est apparu en premier sur Drone-Maniac !!!!!!!.
