A 0.5g nanoreceiver with 1000m of control range for sprektrum radios ?? yes it’s here: http://www.banggood.com/2_4G-8CH-0_5g-DSM2-DSMX-Compatible-Mini-Receiver-With-PPM-Output-p-1102906.html
Both DSM2 & DSMX with 11ms & 22ms (2048/1024) protocols are supported. No information if telemetry is also here.
Item Name: DSM2 DSMX Mini Compatible Receiver
Channel: 8 channels (4-8 can be used)
Frequency Hopping Format: DSSS
Frequency range: 2.403-2.479ghz
Bandwidth: 500khz-876khz
Number of bands: 256
Receiving sensitivity: -97dbm
Input power: 3.0-3.6V
Response time: 22ms / 11MS
Resolution: 2048
Display method: LED
Operating voltage: 3-3.6V
Working current: 30MA
Size: 9.5mm * 10mm
Weight: 0.5g
Each channel data: Depends on the transmitter
Delay: <15ms Antenna length: 26mm Data format (DSC port :): PPM (S801A-P data format is PPM, S801A-D data format is DSM) Distance: no ground interference (1 m from the ground) 1000m
Uses: indoor small aircraft.
Compatible Transmitters: DSM2 / DSMX series of remote control
ANT-Gain antenna, GND-Ground, VDD-Input power, Data-DSM or PPM
Drawing only 30mA too …. really interesting model. Must be wired in PPM or DSM.
If 1000m is not enough, you can have 1500m with a 0.7g and diversity model: http://www.banggood.com/2_4G-8CH-0_7g-Dual-Antenna-DSM2-DSMX-Compatible-Mini-Receiver-With-PPM-Output-p-1102905.html
Frequency range: 2.403-2.479Ghz
Band width: 500khz-876Khz
Receiving sensitivity: -108dbm
Input power: 4-9V
Resolution: 2048
Display method: LED
Operating voltage: 3.3V
Working current: 60MA
Size: 13.5mm * 10mm
Weight: 0.7g
Receive sensitivity: -108DBM
Delay: <15ms Antenna length: 26MM Dual Antenna Data format: PPM (S801B-P data format is ppm, S801B-D data format is dsm) Distance: no ground interference (1 m from the ground ) > 1500m
Be aware, 60mA versus 30mA … for the the diversity model.
It’s just incredible to have such receivers now so efficient. All majors protocols are supported: FrSky, FlySky Futaba and DSMX…..
We can dream of FPV machine under 40g with 1km of range ? Buzzer is a must to have ? of course
Cet article NEWS: 0.5g & 0.7g long range DSM2/DSMX nano-receivers est apparu en premier sur Drone-Maniac !!!!!!!.
