You liked the Runcam Split 2 ? the great combo able to record at 1080p@60 while broadcasting the FPV signal with low latency ? … If yes, you will be crazy about the new incoming shrinked version: the Runcam Split Mini. Oscarliang just grabbed a prototype for a preview: https://oscarliang.com/runcam-split-mini-camera/
Not a lot of informations yet available. The product should be lunched in a couple of days. We can expect more or less the same performances as for the split with a latency in average of 38ms. Notice it’s a double layer system in 20mmx20mm format… Standalone without any screws, standoff and microSD card, the new system weights 14.5g…. Probably we can dream to see such kind of new camera-DVR system
into 3″ FPV racer….
– HD FOV 155° / FPV FOV 130°
– HD Video Resolution / frame rate: 1080p60fps / 1080p30fps / 720p60fps
– Dimensions: PCB 29*27*11mm (20mm mounting pattern) / Lens Module 19*19*22mm
– Power Voltage/Current: 5-17V / 430mA when idle, 540mA-650mA when recording
– Weight: 14.5g without any standoff & screws
– Integrated Microphone (but not for FPV)
Cet article NEWS: Runcam Split Mini est apparu en premier sur Drone-Maniac !!!!!!!.
