A new 3-in-1 AIO FPV camera is announced including also builtin 720p recordings: https://www.gearbest.com/receiver-transmitter/pp_1527671.html
The total weight is annouced to turn around 8g. Can be powered directly from a 1S source ([3.5V – 5.5V]). The module seems small enought to be installed even into < 100mm machines. The camera is basic CMOS model with 120 degrees of FOV. The output power of the 5.8G VTX can be switched between 0mW, 25mW and 200mW. With such kind of product there are some important questions which can be answered only by advanced testings: 1) What will be the extra latency introduced to encode in 720p the video stream and 2) Is a real genuine 720p source recorded or a NTSC one extended to 720p by interpolation ? As usual, Wait & See.... null
Main Features:
Transmitter Module
– Transmission power: 0mW / 20mW / 200mW adjustable power
– Input voltage: 7 – 26V
– Input current: 90mA / 130mA / 230mA
– Output voltage: 4.2V
Camera
Format: NTSC
Output impedance: 75ohm
Voltage DC: 3.5 – 5.5V
Sensor pixels: 130W
Lens: M7, horizontal 120 degrees, vertical 100 degrees
Cet article NEWS: TX1769 3-in-1 AIO FPV-camera-720p DVR est apparu en premier sur Drone-Maniac !!!!!!!.
