Remember the Popular MJX Bugs 3 ? then the B2W, a direct competitor of the Hubsan H501A… Then followed the Bugs 6 a 5.8G beginner cruizer…
Here is a new compagnon for the B6, i.e. the B8-pro in 300mm format: https://www.banggood.com/MJX-B8-Pro-Bugs-8-Pro-5_8G-FPV-Brushless-With-C5830-Camera-Racer-Drone-Quadcopter-RTF-p-1254331.html
The machine is still full plastic based … but shifts from a 2S to a 3S solution thanks to a 1300mAh/45C LiPo. Motors are still 2204 type… Still no open source flight controller installed…. it’s more a plug and fly machine spirit. Another major novelty is the addition of an acro flight mode… ideal for acrobatic flights. There is the type of 5.8G AIO FPV-camera… with a max power of 200mW. The bugs 8 still uses the 2-way radio protocol with basic telemetry alarm for the low voltage and out of control cases. The FPV signal and the control range should be ok under the radius of 200m…. It’s not really a racer, not a docile machine as well … but of the vibrations are ok and the sensivity of the FPV camera acceptable, can be a nice first FPV cruizer acrobatic able too.
MJX_bugs_8_pro_1
MJX_bugs_8_pro_2
MJX_bugs_8_pro_3
MJX_bugs_8_pro_4
MJX_bugs_8_pro_5
MJX_bugs_8_pro_6
MJX_bugs_8_pro_7
Brand Name: MJX
Item NO.: B8 Pro
Item Name: MJX B8 Pro FPV RC quadcopter
Frequency: 2.4G
Channel: 4CH
Battery: 11.1V 1300mAh 45C li-po
Camera:C5830 Camera
Motor: 2204 1800KV Brushless motor
Speed:60km/h
Flight distance: About 300 -500 meters
FPV distance: About 200 meters
FPV camera transmit: 200mw
Flight time:10-12 minutes
Charging time: around 150 minutes
Transmitter Battery: 4*AA 1.5V(Not included)
Color: Black and red
Quadcopter’s Weight: 420g
Quadcopter’s size: 30x30x9cm
Product size:35.7X28X16cm
Function: ascend, descend, forward, backward, left sideward fly, right sideward fly,Inverted Flight, Rolling 180° ,3D Flip
– With 2 flight modes, switching between Angle Mode and Acro Mode enables both beginners and skilled pilots experience the flight fun.
– With 5.8G FPV real-time HD image transmission.
– Flying at up to 60km/h , control range up to 300-500m.
– With 2204 1800KV brushless motor strong power to the quadcopter.
– With 11.1V 1300mAH high-capacity battery give a longer flying time- maximum 12 minutes.
– 2.4GHz Technology Adopted for Anti-Interference.
– 4 Channel which can do ascend, descend, forward, backward, left sideward fly, right sideward fly and rolling 360°.
– 6-axis gyro which can have more stable flying and be easy to control.
– With LED lights making the flight more spectacular especially in the dark.
1x MJX B8 PRO Quadcopter
1x Transmitter
1x Battery
4x Propeller
1 x Blance charger
1 x USB charging table
1 x Propeller fixing mount
1 x Screw
1 x Uv sticker
1 x Manual
First videos already emerged from earlier beta testers:
Cet article NEWS: MJX Bugs 8 pro est apparu en premier sur Drone-Maniac !!!!!!!.
