The FrSky Apus MQ60 is a surprizing product from FrSky more known to deliver excellent 2.4G radio solutions. Here we have a Brushed FPV TinyWhoop machine with classic ingredients: F3 SPracing Evo board but without OSD, 6mmx15mm motors and a simple 600TVL CMOS 25mW 48CH AIO module. Let’s have a look to this product.
+ 1 x FrSky Apus MQ60
+ 1 x 200mAh 1S LiPo with
+ 1 x USB charger
No spare props …. no extra battery…. For A 80USD bundle …. It’s not a good starting sign.
The structure is ultra classic, a 65mm ducted machine in order to improve hoveribility vs the fast mouvements.
The plastic quality is in the average…. not among the best plastic quality I met.
The 5.8G antenna is installed vertically outside the canopy via a top hole on the canopy. It’s a good point for the FPV range.
In the other hand, the camera is installed perfectly horizontally … so not super adapted for fast forward mouvement despite the 120degrees wide angle of the lens.
The left side shows a plastic tab to be press for the Vfreq, Vband selection. As for almost all AIO module, a short press will cycle within the eight Vfreq for selected Vband. A long press will cycle within the 6 supported Vband.
Through the Skyblue canopy color, it’s hard to guess the index of the blue light (Vband) and the red light (Vfreq)… You will probably need to open the machine by removing the small three screwdrivers.
The green small light is the receiver status light. It will flash slowly when the binding procedure is in process and faster when bound. When the binding operation is over… the green light will be turned off.
The microUSB port location is well designed…. ideal to level accelero & gyro when the machine is connected to Betaflight.
The F/S, binding button of the builtin FrSky XM receiver (in D16 mode). The RSSI is sent to the last channel but since there is no builtin OSD… it’s useless.
28.2g AUW…. it’s a lot…. for 6mmx15mm motors
Some 6mmx15mm brushed motors … no RPM mentioned …
a 200mAh 1S LiPo model… no LiHv…. ending with microJST SH (1.25mm) connector.
The dedicaced F3 SPracing Evo with a builtin FrSky XM receiver. The FPV module is plugged via a connector.
The machine integrates a Betaflight 3.3.0 so probably a beta version of the of the incoming V3.3 branch. The machine is tuned to 16000PWM in order to reduce the noise emitted by motors. In the other it will slightly drop the performances of the machine.
After binding (if you have an IR8M radio, set the finefreq option to 63), you need a minimum of 75%-80% throttle input to take off…. Weird…. the machine is absoluptly underpowered….. You will need to anticipate a lot your elevation in your flight.. It’s really annoying. Acro flight with this machine is a dream…. Forget it…. Really motors are not strong enough… The flight time is impacted, about 2min-2min 30…. far from the 5min promised. The LiPo also IMHO is overated in term of discharge rate. The only good news is about the FPV signal… clean with a good range.
What a disapointement ……. probably the worst tinywhoop FPV clone…. I ever tested….. I didn’t find really any positive points for this machine. More the price is very expensive versus competitors….. “Player FrSky shoot again”….. I am not sure that FrSky will continue to produce such kind of machine.
+ Betaflight compatible
+ MicroUSB port location
– Completly underpowered
– Poor flight time (2min30)
– Expensive
– No builtin OSD
Dump_BF_3_3_0_Apus_MQ60
You can find it actually for 80USD at http://www.banggood.com/Cheerson-CX-10C-CX10C-Mini-2_4G-4CH-6-Axis-RC-Quadcopter-with-Camera-RTF-p-989909.html
Cet article TEST: FrSky Apus MQ60 est apparu en premier sur Drone-Maniac !!!!!!!.
