Remember close to 1 month ago I reviewed the Eachine Beecore V2, probably the ultimate flight controller dedicaced to 1S TinyWhoop machine in 26mmx26mm size. Here is the FrSky D16 version:
https://www.banggood.com/Eachine-Beecore-V2_0-D16-Brushed-F3-OSD-Flight-Controller-for-Inductrix-Tiny-Whoop-E010-E010S-p-1267723.html
Here, the FrSky D16 receiver can be turned into 8CH (with lower latency) or 16CH mode but in any case, the RSSI is sent to the last channel for the OSD rig and also sent by telemetry. More it’s compatible with EU-LBT preflashed radiocontrols… So it should work with all FrSky compatible radios. My first concern with the original V2 in D8 mode was the relatively poor performances of the Vreg part (~0.8A). No strong enought and probably full diode based… very sensitive to the voltage drop and requering at least a 40C battery. I really really hope, they improve the situation where for example you could have a receiver brownn out immediatly after the take off. Anyway if this problem is solved, this D16 version will be probably the best we can have for a compact brushed FPV Tinywhoop machine: a strong MCU with an OSD, a great builtin receiver with at least 300m of control range and everything around 3g. Associated with a 3.5g AIO module, Dark edition 7mmx20mm motors, a 66mm frame, you can build the best TW machine ever made. Be sure than a Eachine machine (QX65 Pro ?) will be produced soon in BNF edotion with this board pre-installed. As usual, Wait & See.
Beecore_V2_D16_1
Beecore_V2_D16_2
Beecore_V2_D16_3
Beecore_V2_D16_4
Beecore_V2_D16_5
Beecore_V2_D16_6
Beecore V2.0 D16 version flight controller is a Ultimate version for 1S brushed Whoop racing drone. It’s the world first Tiny Whoop size brushed flight controller with D16 receiver/Betaflight OSD/Telemetry all in one design, include all your needs for FPV racing drone.
Brand Name: Eachine
Firmware: Customized Betaflight_3.3.0_Crazybee
MCU: STM32F303CCT6 (72MHZ, 256K FLASH)
Sensor: MPU-6000(SPI connection)
Power supply: 1S battery input (DC 3.5-4.35V)
Board size: 26 * 26MM
Board weight: 3.0 g
Receiver Parameters:
SPI BUS receiver
Frsky D8/D16 switchable
Channels: 8ch or 16ch
Failsafe support
No ground interference ( Transmitter and receiver 1 m from the ground): 300m
Built-in Frsky receiver with telemetry
Built-in Betaflight OSD(SPI Controll)
Built-in voltage detection
Heading LED Ready
Frsky D8/D16 mode switchable
Compatible with Frsky EU LBT
1 x Beecore V2.0 D16 controller Board
4 x Rubber Shock Absorber
4 x Screws
3 x Power Cable (For Inductrix x1, For E010 x1, For QX Serials x1)
Cet article NEWS: Eachine Beecore V2 with builtin D16 receiver est apparu en premier sur Drone-Maniac !!!!!!!.
