Maybe a solution for futur powerfull microFPV brushless racers. Eaglepower will introduce some 0802 motors under 2g: https://www.banggood.com/Eaglepower-SA0802-1-2S-10000120001400015000KV-Brushless-Motor-for-RC-Drone-FPV-Racing-p-1274947.html
Four models are proposed: 10000Kv/12000Kv/14000Kv/15000Kv…. The two first models are 1-2S compatible and the two last only 1S. This type of model can be installed on a 60mm frame in 2S setup. With a bit of luck, everything can be under 50g even 45g AUW… For 1S setup, around 30g AUW. I am sure we will see soon some machines based on these new motors.
Eagle_Power_SA0802_1
Eagle_Power_SA0802_2
Eagle_Power_SA0802_3
Eagle_Power_SA0802_4
Eagle_Power_SA0802_5
Eagle_Power_SA0802_6
Brand name: Eaglepower
Model:SA0802
KV: 10000/12000/14000/15000KV
Motor Dimensions (Dia.x L): ¢11*9.5mm
Weight:1.95g
Shaft ¢:1.0mm
No.of Cells (Lipo):1-2S (14000/15000KV support 1s)
Propeller:35MM*4 Blade
Applicable models : 60-80 class mini mutirotor
1 x SA0802 motor
