At least a new non-FrSky microreceiver which offers RSSI for the OSD: https://www.banggood.com/IRangeX-Fli14-Flysky-Receiver-with-RSSI-Output-Betaflight-OSD-for-FS-i6-FS-I6X-Turnigy-Evolution-p-1294803.html
The IrangeX Fli14 is a 1g FlySky module supporting AFHDS-2A protocol. The RSSI is exported on the (last) 14th’s channel. The receiver is of course compatible with most last FlySly radios. The control range is announced to be about 300m more or less indentical with any other FrSky D8 micro receiver. It’s a good news for all FlySly’s fans.
i_Range_X_Fli14_1
i_Range_X_Fli14_2
i_Range_X_Fli14_3
i_Range_X_Fli14_4
i_Range_X_Fli14_5
i_Range_X_Fli14_6
Brand Name: iRangeX
Item Name: Fli14 RX
Channel: 14
Protocol: AFHDS-2A
2.4G Mode: The second generation of an enhanced version of the automatic FM digital system
Antenna Length: 50mm (single antenna)
Input Power: 4.0-6.5V DC
Weight: Only 1g
Color: Black
Signal Output: IBUS
RSSI Output: Channel14
No ground interference ( Transmitting and receiving 1 m from the ground): >300m
– Customized for Betaflight
– RSSI Display Via OSD without any hack compatible with all Flysky AFHDS-2A protocol transmitter
– Support RSSI Via Channel14(Aux10 in Betaflight)
– Best for FPV Racing drone
– Compatible with FS-i4, FS-i6,FS-I6X,FS-i6S, FS-i10,FS-iT4S, Eachine I6,Turnigy I6S, Turnigy Evolution
Binding procedure:
1. Power for the Fli14 Receiver while press and holding the bind button
2. The LED will blinking fast , this indicates the receiver is in binding mode
3. Get the Flysky transmitter into binding mode , the LED on the receiver will getting to be solid and this indicates binding successfully
1 x Fli14 RX
