NEWS: iFLIGHT iH3 (3″ FPV racer w/ Runcam Split Mini)
A second FPV racer including a Runcam split mini is announced:
https://www.banggood.com/IFlight-iH3-3-Inch-142_5mm-F3-15A-ESC-5_8G-FPV-Racing-Drone-w-RunCam-Split-Mini-1080P-Camera-p-1309177.html
This one comes after the SPCMaker S125 (soon be reviewed @D-M). The dimensions are slightly larger (142.5mm). The iH3 comes with 1106/6000KV motors coupled with 3″ props. There is also a 15A BLheli_S/Dshot600 4-in-1 ESC board 3S maximum compatible. The flight controller is a classic F3 model in 20mmx20mm format. The full carbon frame offers at least 3mm arms section. The Runcam camera module is well protected from frontal crash and we have the possibility to uptilt the camera. The machine standalone weights 124g… so should converges about 160g with a 3S 550mAh LiPo. Three choices of receiver are proposed: a FrSky solution with the D16 XM+, a FlySky AFHDS-2A and a Futaba FASST.
IFlight_i_H3_1
IFlight_i_H3_2
IFlight_i_H3_3
IFlight_i_H3_4
IFlight_i_H3_5
IFlight_i_H3_6
Brand Name: IFlight
Model: iH3
Item Name: 3 Inch F3 5.8G FPV Racing Drone
Version: PNP ( Without Receiver ) ;
With Compatible Frsky XM+ Receiver
With Compatible Flysky FS-A8S Receiver
With Compatible Futaba FASST MINI SUBS Receiver
Weight: 124.1g ( Not include battery)
Hover Time: 5mins
Wheelbase: 142.5mm
Frame weight: 39g
Bottom plate thickness: 3mm
Top plate thickness: 2mm
Vertical side plates thickness: 2mm
Vertical side plates width: 19mm
Standoffs mouting distance: 22mm
Flight Controller & ESC: 20x20mm IFlight Mini F3 & 15A BLheli_S ESC Flytower
– F3 Integrated with betaflight OSD, 5V@3A BEC output
– BLheli_S firmware, support Oneshot, multishot, Dshot150, DShot300 and DShot600
Brushless Motor: IFlight iPower Force 1106 6000KV Motor
Propeller: Emax AVAN Mini 3024 3-Blade Propeller ( Clear Red Color )
FPV Transmitter: IFlight Force Mini 48CH 25MW/100MW/200MW S.BUS VTX
Camera: Runcam Split Mini 1080P/60fps HD recording & WDR FPV camera
Antenna: Foxxer Pagoda Atenna ( SMA )
Recommend Lipo Battery: 2S 850mAh Or 3S 550mAh ( Not Included in package )
1x IFlight iH3 142.5mm Drone
1x LED w/ Buzzer
1x Strap for Battery
1x XT30 Cable
1x XT30 to JST Cable
1x Magic Tie
