I don’t announce often for brushed quadcopters because in general there are only very slight improvements versus the billion of models introduced in the market permanently. Here is a new one able to FPV in 1080p with a wide angle (seems about 120 degrees according to the photos). Ok it’s not new… but this one also, i.e. the Cheerson CX39: https://www.banggood.com/Cheerson-CX39-WIFI-FPV-With-1080P-Camera-Altitude-Hold-Mode-Voice-Control-RC-Drone-Quadcopter-RTF-p-1339075.html can record inboard the native 1080p@30fps source…. That’s a good forward step. There is a builtin GPS module offering classic advanced modes such as RTH or orbit mode. More, the CX39 offers the possibility to lunch some actions via some voice commands. Be aware, the FPV signal is broadcasted in the 5.8G WiFi band… so no all (europeean) android will be comptible with (some 5G/5.8G channels are not opened for europe and in general chinese quadcopters open only the CN/US channels). The machine is a 230g brushed geared 1S one with a flight time advertized up to 12min. Of course with this kind of machine… it’s strongly advised to stock in advance some spare motors as soon as tbey are available. Wait & See.
Cheerson_CX39_1
Cheerson_CX39_2
Cheerson_CX39_3
Cheerson_CX39_4
Cheerson_CX39_5
Cheerson_CX39_6
Cheerson_CX39_7
Cheerson_CX39_8
Brand name: Cheerson
Item name: CX39 RC Quadcopter
Item No.:CX39
Color:Red Blue; Black Orange.
Frequency: 2.4GHz
Channel: 4CH
Gyro: 6 Axis
Quadcopter Size: 31*32*9cm
Blade diameter: 14cm
Quadcopter Weight: 230g(with battery)
Quadcopter Battery: 7.4V 900mAh (included)
Quadcopter Battery Charging Time:150mins
Flight Times:12mins
Transmitter Battery: 3.7V 2200mAh (not included)
Remote control battery life:about 80mins
Transmitter Charging Time: 150mins
Flight Distance: 300-500m
Flight speed: <30KM/h Flight mode: headless mode, GPS mode Flight environment: indoor, outdoor R/C Distance:about 100m Wifi 5G R/C Distance:250 meters Camera: 1080P/720P (Adjustable) Video resolution: 1080×1920
Frame rate: 30 frames / sec
Camera angle: manual
Recording format: mp4
Photo format: jpg
– Forward and backward, left fly, right fly, left rotation, right rotation, one-button takeoff, one-button landing,
– With backhaul function, the phone displays the height of the aircraft, the number of satellites, heading, horizontal speed, vertical speed and current battery level, etc
– The aircraft has a low voltage 30 seconds automatic alarm and automatic landing function to further improve the safety of the flight;
– Large capacity smart battery with battery indicator for easy plug-in battery structure, longer battery life and faster battery installation;
– With one-button return and out of control return function, making over-the-horizon flight safer;
– The aircraft has three speeds: high, medium and low speed freely switchable to adapt to different flight environments;
– The concept of camera and video transmission integration, camera video, simpler shape, more convenient operation;
– Turn on the GPS mode hotspot surround function to control the surround radius;
– One-click 360-degree panoramic video, 5G WIFI for iPhone 5 and above, not for Android;
– The aircraft inserts the SD memory card to save the video as 1080P, the mobile phone 5G WIFI saves the video as 720P, and the receiving range is about 200 meters.
– The latest mobile phone 5G WIFI remote control operation, FPV screen real-time transmission, experience the first flight person called vision.
– The latest voice control function can perform a variety of flight actions through the APP voice command aircraft, and the voice interaction is fun and fun;
– Needn’t judge the head position thanks to the headless mode function
– The camera angle can be adjusted manually;
Function: Up/down, Forward/backward,Turn left/right, Sideward flight, LED Light, Headless Mode, 3-level flight speed;One Key Automatic Return,high hold mode;WIFI FPV;
1 x CX39 Aircraft
1 x Transmitter
1 x 7.4V 900mAh Battery
4 x Propeller
4 x Protection Guard
1 x USB Charging Cable
6 x Screw
1 x Screwdriver
1 x English Manual
