I was sure after the introduction of the Runcam Split Mini 2 that the first micro-racer with a builtin model will be soon introduce. And it’s already the case with the new SPCMaker SPC-K1: https://www.banggood.com/SPCMaker-SPC-K1-95mm-Omnibus-F4-20A-BL_S-FPV-Racing-Drone-PNP-BNF-w-RunCam-Split-Mini-2-Camera-p-1357411.html
We have a super compact 95mm machine, 4S compatible with strong 1105/6000 KV motors, 20A 4-in-1 ESC board Dshot 600 compatible. The frame is 3K based with main probably 2mm arms. The machine without battery and without receiver is about 91g !!! so around 93g with a receiver and add 40g more for a 4S 550mAh battery. Really impressive for a machine able to shoot 1080p@60fps video. The machine is sold in PNP version or in four different BNF versions with classic option: FrSky D16, FlySky AFHDS-2A, Spectrum DSM2/X and Futaba. I really hope the split 2 mini will be connected to a spare UART port of the FC in under to control dedicaced OSD options and video triggering. After the good SPCMaker S125, this SPC-K1 looks like even better. The new 2.5″ reference ?. I will ask one for review.
SPCMaker-_SPC-_K1_1
SPCMaker-_SPC-_K1_2
SPCMaker-_SPC-_K1_3
SPCMaker-_SPC-_K1_4
SPCMaker-_SPC-_K1_5
Brand Name: SPC Maker
Model: K1
Item Name: 95mm Omnibus F4 FPV Racing Drone
Wheelbase: 95mm
Material: 3K Carbon Fiber
Version: PNP ( Without Receiver )
Compatible DSM2/X Receiver
Compatible Frsky Receiver
Compatible Flysky Receiver
Compatible Futaba Receiver ( Optional)
Weight: 91g ( battery not include)
Omnibus F4 Flight Controller
Item Name: Omnibus F4 Flight Controller Integrated with OSD PDB BEC
Firmware: OmnibusF4SD
Main Chip: STM32F405
MPU6000 6 aixs SPI Gyro & Acc
BEC: 5.1V@1.2A
Mounting Hole: 20x20mm
Weight: 3.5g
DShot1200 Support
SBUS/PPM and Speketrum DSM Ports 5.5V BEC Support
Brushless Motor
1105 6000KV Brushless Motor
20A BL_S 4in1 ESC
Item Name:20A BL_S 4in1 ESC
Con. Current: 20A
Input Voltage: 2-4S Lipo Support
BEC: NO
Firmware: BLheli_S
Dimension: 29x31mm
Weight: 4.9g
Support DShot150, DShot300 and DShot600
Don’t Recommend PWM
Emax Avan Blur 2 Inch Propeller
Item Name: Emax Avan Blur 2 Inch 3-Blade Propeller
Diameter: 2 inch
Pitch: 1.9 inch
Weight: 1.1g
FPV Transmitter
Item Name: 5.8G 40CH 25mW 100mW VTX
Input Voltage: 5-6V
Operation Current (5.5V) : 310mA@25mW, 350mA@100mW
Frequency: 5.8G 40CH 5645-5945MHz
FPV Camera
Item Name: Runcam Split Mini 2 Camera
Field of View(FOV): FPV FOV 130° / Recording FOV 165°
Video Resolution: 1080@60fps / 1080@30fps / 720@60fps
Video File Format: MOV
Image Resolution: 2 MP
TV Mode: NTSC (720*480) / PAL (720*576) Switchable
Interface : JST 1.0mm / UART
Max Micro SD Card Supported: 64G(need Class 6 or above, recommend Class 10 / UHS-I / UHS-II / UHS-III)
Hole Distance of Installation: 20*20mm
Dimensions: PCB 29*29mm / Lens Module 19*19mm
Power Input: DC 5-20V
Working Current: 650mA @5V / 270mA @12V
Weight: 12.5g
Receiver
Without Receiver Version : No Receiver
Compatible DSM2/X Receiver Version: DSM2/X Receiver
Compatible Frsky Receiver Version: Frsky Receiver
Compatible Flysky Receiver Version: Flysky Receiver
Compatible Futaba Receiver Version: Futaba Receiver
1x SPC K1 95mm FPV Racer
1x Battery
1x Strap
