WiFi toyquadcopter made a lot of progress since one year. From basic 720p camera with a narrow field of view and basic flight assistance, now with the Eachine E511S: https://www.banggood.com/Eachine-E511S-GPS-Dynamic-Follow-WIFI-FPV-With-1080P-Camera-16mins-Flight-Time-RC-Drone-Quadcopter-p-1373965.html
we have a foldable machine able to record up to 1080p with a FOV of 120 degrees. More thanks to a builtin GPS you will enjoy advanced flight modes such GPS positionning, RTH, follow-me, path planning. No mention about specific selfie fligth modes, a very important missing information if you plan to use this machine as a firt selfie drone… The camera can be tilted up and down via the radiocommand. It’s a brushed machine with 1020 coreless motors so the largest brushed motors actually available. Of course with brushed machine always take into consideration that such motors have a limited life. If you think to buy this machine, always also order at least a CW and a CCW motors. With a 1200mAh 2S LiPo, the promised flight time is about 14min… In term of control range about 200-300m… but I am not sure despite the 5.8G WiFi link such distances can be reached. For europeans android users, take into consideration that probably the selected 5.8G WiFi channels won’t be compatible with your device except if Eachine added a procedure to change these channels according to your local zone. More, three versions are proposed: one 720p, one 1080p and one 1080p 5.8G WiFi. If for the two first it’s clear that the video is stored locally on the quadcopter via a microSD card… it’s not clear for the 1080p 5.8G model if also the native video flux is also stored onboard or only via your smartphone. If the last hypothesis is true, the machine looses a lot of interest. Other questions emerge also from the camera module: What is the frame rate ? what is the light sensitivity… At least for sure for such price don’t expect EIS feature to stabilize your video recording… So many questions at end. Only a complete review will answer
Eachine-E511-S-8
Eachine-E511-S-1
Eachine-E511-S-2
Eachine-E511-S-3
Eachine-E511-S-4
Eachine-E511-S-5
Eachine-E511-S-6
Eachine-E511-S-7
Brand Name: Eachine
Item NO.: E511S
Frequency: 2.4G
Channel: 4CH
Gyro: 6 axis
Motor: 1020 Coreless Motor
Quadcopter Battery: 7.4V 1200mAh Lipo (Included)
Transmitter Battery: 3 x 1.5 AA battery (NOT Included)
Flying time: 14-16mins
Charging time: 120-150mins
R/C Distance: 200-300m
Color: Black
Camera Optional: 720P / 1080P / 5G WiFi 1080P
FOV: 120° Wide Angle
Quad’s Size: 35.4×36.6×7.3cm (the arms not folded, with props guard)
18.5×10.8×6.4cm (the arms folded)
– With foldable arm, small size, easy to carry.
– GPS positioning mode provides a more accurate flight.
– With wifi function can be connected APP, APK system to take pictures, video, real-time transmission through the phone camera image.
– Optional 720P / 1080P / 5G WiFi 1080P HD camera give wide range high denfinition pictures and video.
– Camera with Servo that support adjust the angle by APP.
Surround action will enable the aircraft flying in a circle, providing cooler shooting perspective.(outdoors only)
Follow me: the aircraft will fix the controlling cellphone and follow the operator whichever direction he moves.(outdoors only)
Waypoint flight mode, just draw a route on the screen, the copter as the given path.(outdoors only)
– With altitude hold mode function provides stable flight.
– With 3.7V 1200mAh battery, the fly time up to 16 mins.
– With Headless Mode,no need to adjust the position of aircraft before flying .
– With One key to return function makes it easily to find the way home.
– with low power protection overcurrent protection.
– 2.4GHz Technology Adopted for Anti-Interference.
– 4 Channel which can do ascend, descend, forward, backward, left sideward fly, right sideward fly and rolling 360°.
– 6-axis gyro which can have more stable flying and be easy to control.
– It have 3-level flight speed to switch that can make more fun with the flying.
– It can realize 3D tumbling 360°rolling in four directions with 4 LED lights.
– The quadcopter fuselage is made of high strength and resistant engineering plastics,lightweight and durable resistance.
Function: Up/down, Forward/backward, Turn left/right, Sideward flight, 3-level flight speed, LED Light, Headless Mode, GPS Positioning, Follow Me, Surrounding Flight, Waypoint Flight, Altitude Hold Mode, WiFi FPV, Camera/Video
1 x Eachine E511S RC Quadcopter
1 x Transmitter
1 x 7.4V 1200mAh Lipo Battery (Can be choose the battery quantity when order)
1 x USB Charging Cable
4 x Protection Cover
2 x Spare Blades
1 x Screwdriver
1 x User Manual
