NEWS: GEPRC Cygnet, a 145mm FPV racer with a Runcam Split Mini 2
Another FPV racer with a builtin Runcam Split Minit 2 is announced with the GEPRC Cygnet: https://www.banggood.com/Geprc-GEP-CX-Cygnet-145mm-3-Inch-RC-FPV-Racing-Drone-Stable-F4-20A-48CH-RunCam-Split-Mini-2-1080P-HD-p-1380268.html
Here we have a larger 145mm machine with 3″ props for a weight announced about 131g without battery. the main 3K carbon structure got 3mm arms coupled with some aluminimum vertical element. For the electronic a powerfull F4+BFOSD board, a 4-in-1 20A 4S compaticle ESC boar, 1206/4500KV motors. The RCSM2 is associated with a 48CH 5.8G VTX outputting up to 200mW. The machine is proposed in BNF with two types of FrSky receiver: i) a classic 2.4G FrSky XM+ or ii) via a 868Mhz/900Mhz FrSky R9 for super long range. For example 6mins of flight time is announced with a 3S LiPo of 850mAh to shoot beautifull videos (at moderate speeds). If you want more action, 4min with a 4S 650mAH Lipo can be obtained.
GEPRC-cygnet-1
GEPRC-cygnet-2
GEPRC-cygnet-3
GEPRC-cygnet-4
GEPRC-cygnet-5
GEPRC-cygnet-6
Brand name: Geprc
Item name: GEP-CX Cygnet
Frame kit: GEPRC GEP-CX3
Wheelbase: 145mm
Weight: 131g(not include battery)
Flying time: about 6mins(3S-850mAh) / about 4mins(4S-650mAh)
Props: 3inch
Carbon fiber thickness: 3mm top plate+3mm bottom plate
CNC: CNC 7075 aluminum
Tail: 3D printed TPU materail+LED
Motor: GEPRC GR 1206 4500KV
Stable Mini Flytower F4-20: Betaflight F4 OMNIBUS flight controller
20A BLHeli_S/Dshot150/300/600 ESC
GEP-VTX58200 48CH Mini FPV Transmitter(OFF/25/100/200mW)
Camera: RunCam Split Mini 2 1080P HD
Propellers: Emax AVAN Mini 3024
Receiver: PNP(without receiver) / BNF(XM+) / BNF(R9MM)
PNP version:
1x GEPRC GEP-CX3 frame kit
4x GEPRC GR 1206 4500KV motor
1x Stable mini flytower F4-20A-VTX58200
1x RunCam Split Mini 2 1080P HD camera
4x Emax AVAN Mini 3024 propellers
BNF version:
1x XM+/ R9MM receiver (option)
