NEWS: AOMWAY NEXUS HD FPV system
Drone News
It’s official … 2017 will be the FPV HD year…. A new complete TX/RX solution from Aomway is now announced with 1080p@30fps, i.e. the Nexus V1: http://www.banggood.com/Aomway-NEXUS-V1-FULL-HD-1080P-10CH-AV-FPV-Transmtiter-Receiver-TX-RX-Combo-p-1099344.html?
No indication of the latency and the weight of the transmitter …. Probably dedicaced for > 250mm machine ….
NEXUS is used for HD image transmission. It adopts the advanced video processing technology of efficient coding algorithm, improve the code efficiency, reduce the coding delay and decrease the bit error rates, to improve the image quality and stability. To realize an optimum image effect at the lowest code rate.
Description :
Brand Name : Aomway
NEXUS HD TX :
Low frequency, Middle Power Transmitter
Working Bandwidth : 8MHZ
Channel : 10CH, Swithable
Input Voltage : LiPo3-4s(DC10-17V)
Antenna Output : SMA, 50O(not included)
HDMI Input : Standard Type A, Support 1080p 30FPS and 720P 30PFS
Max. Power Consumption : 9W/+39.6dBm
LED Indicator : Red : power
Blue : signal
Built-in Fan : 2507 High speed high efficiency fan
Working Temp. : 0-80?
NEXUS HD RX :
Working Voltage : DC7-24V
LED Indicator : Red : power,
Blue : signal.Auto search signal when power on, LED flashs; when it receive the signal, it turns to constant; If there is no sinal, the LED off.
Delay : 80ms(not include the camera and monitor)
Sensitivity : -82dBm (64QAM, 8M/FFT:8K, GI:1/32, CR:7/8)
Power Consumption : <4W Working Temp. : 0-60? Package Included:
1 x Aomway NEXUS V1 HD Transmitter
1 x Aomway NEXUS V1 HD Receiver
Cet article NEWS: AOMWAY NEXUS HD FPV system est apparu en premier sur Drone-Maniac !!!!!!!.
